60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Mar 11, 2023 at 5:57 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I ran CAT5e when the walls were open here, 20 years ago. I still don't have speed issues related to the wiring. IMO the network cable specs are pretty conservative. One thing's for certain, I won't be ripping the walls open again! :)
  2. Mar 11, 2023 at 6:14 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Extenders are a compromise where you can’t run Ethernet. The main issue is that extenders share the same or steal a wifi channel from the router. They are also half duplex which means signals can only go one direction at a time. There is a lot of retry’s when sending IP packets because it has to wait for the channel to free up. Thats why it’s typically half speed or less. The type of connection to the router from the other access point (extender) is called a back haul. To get full speed you must hardwire the back haul using Ethernet. That may not be easy when you need wifi out in a garage 100 feet away. If you have the money look at a NETGEAR Orbi 6 or 6e (overkill). It uses a dedicated channel for the back haul. It will still struggle with going through metal based insulation, doors, and e glass via wifi. It will run full 1Gbit if you can put run Ethernet back haul. I did this outside in my covered patio.
  3. Mar 11, 2023 at 6:57 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Good Evening Porch Pals & Sue! Long day!
    Huge crowd. Folks everywhere. But, on with the show! I promise a totally random assortment!
    I actually passed (no kidding) this guy on the highway. Really need those beautiful headlights aligned! Which, is probably why I passed him....
    ScrippsRanch67, JGO, wdb and 11 others like this.
  4. Mar 11, 2023 at 7:38 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Evening all:
    As usual, nice car pics Kurt, that 63 Galaxy is really nice, looks to be a 390 which was pretty common.
    :( not looking good, now a major bank failure, maybe gonna be a bit of a rough ride coming up.
    johneman[OP] and davidstacoma like this.
  5. Mar 11, 2023 at 8:01 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    What is #98?
    The VW busses in original patina are so cool...
    And the new Broncos are not impressive, at all. Has Ford ever made anything more bland?
  6. Mar 12, 2023 at 1:04 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning fellow Porchatonians!!!
  7. Mar 12, 2023 at 4:31 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Kurt: all the pics were nice. Enjoyed the GTO and the VW bus pics. Such a wide variety of cars and trucks.
    Good morning.
    The extender installed really easy. Both Wi-Fi networks came up with no problems. The speed was what I expected, about 1/3 the speed as opposed to the router Wi-Fi. The MOCA backhaul worked pretty well. I could also use my ethernet connection, but I wanted to leave it dedicated to the ethernet switch in the room. I did achieve the desired results, now my Wi-Fi smart switch, controlled electrical outlets, are now working fine with no going in and out of service that was happening on a regular basis. I cannot recommend BN-Link products unless you have a strong W-Fi signal to the area they are installed.
    Today is a birthday party for my sister. She is now 70 years old. The switch over yo daylight savings time was pretty hard this morning. Went to bed at 10:30 last night and woke up at 6:30, so 7 hours of sleep. Off to the gym then home to make breakfast for the family. I have been watching old James Bond movies, Sean Connery, for about 2 weeks now. Watched Diamonds are Forever last night. Bond movies always have such beautiful women in them. Jill St. John did not disappoint. Need to find Goldfinger to complete the Sean Connery watch list.
    Sprig, Oldie2007, JGO and 3 others like this.
  8. Mar 12, 2023 at 5:35 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    I'm guessing you're referring to the red custom...looks like it started life as a '58 Ford
    Oldie2007, JGO and johneman[OP] like this.
  9. Mar 12, 2023 at 5:48 AM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    your Bond marathon watch must have left you all warm and fuzzy. My marathon, Showtime’s Waco, had a much different effect. Having lived through those days with eyes wide open, I expected more of a yawn than was delivered. I was physically shaking, with that hollow delicate stomach feeling for quite a while afterward. The blind horror of knowing where it would inevidently be going was as powerful as any personal drama could have been. I won’t soon forget this one.
  10. Mar 12, 2023 at 6:06 AM
    boatswain
    carl
    palmerton,PA.
    Morning all:
    OOPS, forgot to change the clocks, good thing that Tom brought it up! :oops:
    Happy Birthday to your sister Tom.
  11. Mar 12, 2023 at 6:36 AM
    Travlr
    Middle'a Utah
    What is this car? An XKE? Daytona? Or?
  12. Mar 12, 2023 at 6:40 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Daytona coupe replica
    Oldie2007 and johneman[OP] like this.
  13. Mar 12, 2023 at 6:47 AM
    Travlr
    Middle'a Utah
    Hard to tell. We need a shot from the back. The iconic rear end. One of Ford's best designs...
    johneman[OP] likes this.
  14. Mar 12, 2023 at 7:02 AM
    johneman
    johneman [OP] Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    Morning Porch Folks :hattip:
    Thanks for posting the pictures Kurt. Always look forward to enjoying them :D:thumbsup:. Quite a few memories of past years there. Thanks again.
    Happy Birthday :hbd: to your sister Tom. Wishing her a great day.
    Have a good day and a safe one.
    :oldglory:
    CTSpruceMica, Oldie2007 and JGO like this.
  15. Mar 12, 2023 at 7:29 AM
    wdb
    Dave
    the perimeter
    plain jane
    Pete Brock designed it for Shelby Racing. Nobody in the shop thought it would work and he ended up hacking the first one together with some plywood bucks and the help of a couple of crew members in their spare time. Shelby was one of the big doubters. Then they took it to Riverside where it hit 186MPH on its first outing! It went on to beat the Ferraris for the GT World Championship, in spite of Enzo cheating by having the last race canceled. Carroll Shelby then showed just how much he disliked the cars by refusing to pay to have them shipped back to the US. They very nearly got dumped in the Atlantic Ocean because nobody wanted to pay the enormous tax if they stayed in the UK. Eventually cooler heads prevailed and they were flown back to California, where they languished in a corner of the Shelby American shop for a while. Nowadays they bring 8 figures at auction. Go figure.
  16. Mar 12, 2023 at 8:19 AM
    Travlr
    Middle'a Utah
    Remember the Olds powered Shelby Series 1? I've always wondered how they have weathered time. I've only seen one, and that was brand new on a showroom floor. Never saw one on the road.
  17. Mar 12, 2023 at 8:23 AM
    Oldie2007
    Kurt
    Lockhart, TX
    Good Morning Porch Pals & Sue! Putz the car and garage clocks, and I think I'm getting started on pulling the Decked system out of the truck today. It's sold as of this coming Saturday.
    Yes, #98 is a Shelby Daytona - more likely than not a replica; 1 because it's regularly raced! 2 there are a lot of battle scar welds you can't see. Here's some shots from last July. I have never got a shot of the complete car, because there is ALWAYS someone very close by.
    Yes, indeed, the red custom was a 58 Fairlane. I will likely not find the FB post from the family - a kid just completed it - his first build. I caught it out my window on the way out.
    FB organizers posted that there were an estimated 1600 cars in the "Show" areas. Of course, I am one of those, so..... Others posted up in the C&C FB page pics of cars I didn't even glimpse.
    johneman[OP], mit88, JGO and 3 others like this.
  18. Mar 12, 2023 at 10:16 AM
    wdb
    Dave
    the perimeter
    plain jane
    I've never seen one in person. It wasn't a real big seller.
    Definitely a replica. There were 6 coupes originally, plus Pete Brock and a couple of his buddies put together some very faithfully reproduced "continuation" units. 20 or so I think. They're all small blocks. Here are some pics of one of the original 6, currently on display at Simeone Museum in Philly. Note the Halibrand mags, 15" I think. Also look at how much ground clearance the car has. Simeone cars are pretty cool because if at possible they preserve them as they were in period, rather than restore them. This car is definitely a preserved one.
    [​IMG] [​IMG] [​IMG] [​IMG]
    johneman[OP], JGO, blu92in99 and 3 others like this.
  19. Mar 12, 2023 at 10:40 AM
    Travlr
    Middle'a Utah
    I doubt anything with a less than 250 production run would be defined as a big seller.
  20. Mar 12, 2023 at 11:07 AM
    Oldie2007
    Kurt
    Lockhart, TX
    Those Shelby Olds were built with all the care and forethought of the Omni GLH. Sign here, please ..
    johneman[OP] and CTSpruceMica like this.
