60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Apr 27, 2023 at 11:14 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Always flush the first half of the list, and you will never be behind on your chores. Or that is my philosophy.
  2. Apr 27, 2023 at 11:53 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I'm thinking about replacing my plugs. I'm at 92K (?) and should be about ready in another hundred thousand miles or so.
  3. Apr 27, 2023 at 1:04 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    That was the 6th time I've done it. I have to eat a big crow and say that I'm still suffering from using anti-seize on the first plug change. I was adamant that you should use it. I was so wrong. Every time I've done it since the plugs spin out with resistance. The sleeve in the spark plug socket stayed on the plug on #4. I pulled the brand new unused plug back out to fix the issue. I noticed old crud from the prior anti-seize'ing on the new threads. I cleaned them off and it went back in much easier. I wish I never did it.
    Oldie2007, 06Tacooo and johneman[OP] like this.
  4. Apr 27, 2023 at 1:13 PM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    This is why I joined Golfers Anonymous. I never could cure the slice. One day I was standing on the tee of a dogleg left, knew what would happen, pulled my ball and tee back out of the ground, put them and the club back in the bag. That was the last time I played. Probably 1976 or so.
    Perhaps @Tacoma Mike could chime in but I'm wondering how well a few shots of carburetor cleaner might do to clean the gunk out. You'd get some in the combustion chamber but I'm not sure how much harm it would do.
  5. Apr 27, 2023 at 1:49 PM
    Tacoma Mike
    Southern Maine
    I bought my house from doing engine work from people “insisting” on using never seize.
  6. Apr 27, 2023 at 1:50 PM
    Travlr
    Middle'a Utah
    The big question... is why do you replace plugs that often? This isn't 1967 and you don't have to do a tune-up every 18K miles.
  7. Apr 27, 2023 at 2:04 PM
    Tacoma Mike
    Southern Maine
    Well, i wouldn’t do that.
    Now you can take this for what it’s worth.
    when I have to repair this crap I tell customers there is risk.
    So, I do not spray anything in the cyl or threads.
    I actually tap the threads. When the tap comes out I clean off the tap and do it again.
    Then, I take my shop vac with an adapter that fits into the plug hole and suck out the cyl.
    Much easier to vac hard never seize than stuff you just softened up.
    I just use motor oil for the threads.
  8. Apr 27, 2023 at 2:06 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Afternoon all:
    Why don't you guys with a slice just aim off to the side and let the slice bring the ball back on the fairway, of course if you do manage not to slice here and there, you will be playing the ball out of the woods! Just trying to help!! :D
    My buddy who owns the 65 FI Vette collected BUSEL BASKETS of errant golf balls from his property, apparently a lot of other golfers have the same problem! :laughing:
    When I get up my motor is running, problem is that most of the time it just stays on IDLE and never revs up, that's when I get nothing done and just add to the list, today was one of those days! :facepalm: WTH, isn't that what being retired is all about, I'll get to it when I either have to or want to! :D
  9. Apr 27, 2023 at 2:25 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I used motor oil when I nailed the hangers on my deck. I used rough cut locust wood. It is believed that you cannot nail into locust. A log cabin maker/carpenter friend looked at it, said "How did you nail into locust?" I said "I dipped the nail in motor oil." He said "Oh!"
    I only use anti-sieze on camp stove parts that I want to remove later.
  10. Apr 27, 2023 at 3:11 PM
    knayrb
    Bryan
    Pure stock
    Because it uses copper plugs. Toyota recommends new ones every 30K miles.
    Oldie2007 and johneman[OP] like this.
  11. Apr 27, 2023 at 4:01 PM
    Travlr
    Middle'a Utah
    Really? I wonder why copper? I might need an owners manual. That's what I get for buying used. In any case I think I'll wait until the truck tells me. I like seeing just how overly cautious manufacturer's recommendations are.
  12. Apr 27, 2023 at 5:22 PM
    knayrb
    Bryan
    Pure stock
    I believe in anti-seize except on lug nuts, spark plugs, and anything needing thread locker. The chrome coated plugs like ours don’t need it.
  13. Apr 27, 2023 at 5:57 PM
    Tacoma Mike
    Southern Maine
    Serial #1 car…
    Just sold it last year..
    ndoldman59, 95SLE, 06Tacooo and 10 others like this.
  14. Apr 27, 2023 at 7:10 PM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    It's official; I finally kissed my Kurt Vise.
    I've been machining stuff for thirty years but never hit the table or the vise until tonight.
    3/4" carbide end mill, going to town on a hunk of 6061 aluminum. Well, I hadn't tightened the collet tight enough, and the cutter shift down. Darnit!
    Another first was an aluminum chip that flew up and over my safety glasses landing in my eye. Aluminum swarf thankfully isn't sharp, but also, you can not
    a magnetic to fish the chip out of your eye. Thankfully I keep tweezers inside my Gestener toolbox (that's why they have a mirror inside the lid) for such
    occasions. Thankfully I got the chip out, no E.R. trip this time.
    Time for a beer!
  15. Apr 27, 2023 at 8:20 PM
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    Can’t like this. Glad the damage wasn’t too bad.
  16. Apr 28, 2023 at 1:56 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning fellow Porchatonians!!! And OUCH!!!!! @roundrocktom Thankfully, no damage was done to the eye.
    ndoldman59, RustyGreen, Sprig and 4 others like this.
  17. Apr 28, 2023 at 2:44 AM
    Tacoma Mike
    Southern Maine
    It’s not if it will happen, it’s when. Glad you’re ok..
  18. Apr 28, 2023 at 3:10 AM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    Is that a true Shelby car?
    My dad says he remembers one in the 1 car showroom Toyota dealer in Lansing MI. Back then he was not a Toyota fan. Looking back, he should have bought that instead of the GTO he had. FYI, I'm only 40 but I get along with most anyone.
    ndoldman59, knayrb, Oldie2007 and 3 others like this.
  19. Apr 28, 2023 at 3:23 AM
    Tacoma Mike
    Southern Maine
    That is the serial number one car. THE CAR.
    We had both race cars at one time.I drove the 33 car in a video.
    They restored both of them before I came on the scene. The was over 30 years ago.
  20. Apr 28, 2023 at 3:32 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    The escrow company let you down, I would contact them first. Depending on your state you may be responsible for the taxes due.
    Mike: I was not expecting such a detailed reply. Thank You. I knew it would be about parts but to have the broken parts measured and machined is new to me. It has to be a compentent machine shop that will do the work. I can imagine it took a while to find a shop that you can trust.
    Welcome to being over 65. It is humbling to take an hour to do a half hour job.
    Good morning. Supposed to rain all weekend with a break during the day on Saturday. Cooking a pork shoulder on Sunday so the umbrella will be up. Cleaned out the big shed early yesterday, when I came home from the gym. Lots of space in the shed now. Stuff was just everywhere and not put away. We had two of the 55-gallon drum liners filled with stuff that was broken, worn out or just not needed.
