60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Dec 15, 2023 at 2:58 PM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    I am debating installing a remote oil filter.
    https://www.baxterperformanceusa.co...k-cartridge-to-remote-adapter-multi-port.html
    Pro: no dropping that 47-pound steel skid plate. The aluminum was 22 pounds, but I destroyed it on a pancake rock that flipped up. It did its job, but ouch!
    Filter up top (like those Gen 2 Tacomas) means I won't hesitate to change the oil and filter before it hits 5,000 miles.
    Con: Cost and it increases "possible points of failure" (two hoses, four fittings).
    I'm off-road often with the truck, so there are no Fujimoto quick-release valves. I like them, but not for off-road. I am a stickler for using a torque wrench and new crush washers (the dental pick occasionally needs to snag the old one off the pan).
    Years back, a friend added an oil filter to his Stinson 108-3. Initially, there was no filter on those Franklin Engines. So, the filter seemed like a good idea until we burst a hose at 8,000 ft. Pucker factor time. He called for Mayday, two souls on board (gulp), but perfect dead engine landing. Fire and rescue were there to guide us back in; a local reporter was disappointed to see a perfect landing. "Were you scared?" The "No Comment" nonevent made the local news, but not with us in it! He installed new hoses, but a few flights later, something happened. Aeroquip had a manufacturing defect, passed testing, but blew with hot oil pressure. Oops. I think he sold the plane without the remote filter.
  2. Dec 15, 2023 at 3:09 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Oldie2007 likes this.
  3. Dec 15, 2023 at 3:35 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Once I ran out of headlights to work on, and the rain hadn't started, time to make some fender flare repair clips. Didn't work to well to start, as all the flat pieces you see were rejects before the first "good" one, that would actually grip a mounting clip. But the ones that were gone, that I made total replacements for, will probably be put on with a mastic, so that they will move a little when put in place. All the original clips have holes "bigger" than the clip, but they were all on just fine, even missing some. So........should work! Putting them on will come next week.
    Onward.....
    RustyGreen, 95SLE, Devious6 and 2 others like this.
  4. Dec 15, 2023 at 3:39 PM
    Oldie2007
    Kurt
    Lockhart, TX
    ndoldman59 likes this.
  5. Dec 15, 2023 at 9:04 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I faced the same situation. Fortunately I’ve retired and don’t have to go to work every day. So my solution was to schedule my laser cataract surgery with the second eye done only 2 weeks after the first. Dr. said some people just take the lens out of the glasses for the eye you’ve had the surgery on and that’s just what I did lol. Happy with the results, I got the long distance lens and use reading glasses for up close tasks. No regrets I see everything driving very well now.
  6. Dec 15, 2023 at 11:03 PM
    mit88
    mit88 Well-Known Member
    Planet earth
    The lights look great!
  7. Dec 16, 2023 at 1:21 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning fellow Porchatonians!!!
    We started the renovation work on the living room of our old farmhouse. After starting into it with our contractor we decided to strip the walls back to the original framing and replace all the wiring/boxes/switches and drywall it instead of trying to repair all the old plaster over lathe. The original structure dates back to sometime in the later 1800s and we confirmed our thought that it started out as a 2 room house - 1 room downstairs and one upstairs. You can see the interior wall that has plaster over lathe on the opposite side which is where they eventually added a room that is now a bedroom as well as where windows were closed in over time. It was cool to find remnants of the wallpaper scraps that they used to "insulate" the outer walls when the house was built. No treasure maps or bags of cash in the walls, though. :(
  8. Dec 16, 2023 at 1:51 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Morning folks :hattip:Don’t understand why I get up at the regular work time. Haven’t worked in almost a year, I guess a 45 year old habit is hard to break. Be safe and have a good one.
  9. Dec 16, 2023 at 4:06 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    My upgrade was out of necessity. My old tablet was not able to log on to Wi-Fi in hotels and a lot of public restaurants. So far the conversion is going very well. I have a problem with only 2 apps so far. For less than $250 I think I am doing pretty well.
    Good morning. Not a good day yesterday. My SIL passed on. Today we are headed to Michigan at 8am.
  10. Dec 16, 2023 at 4:08 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning 60+ :hattip:
    Oldie2007, Sprig, ndoldman59 and 2 others like this.
  11. Dec 16, 2023 at 5:09 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Morning 60 + :hattip:
    Rain in the forecast
    Have an awesome day !!
    lynyrd3, Oldie2007, Sprig and 3 others like this.
  12. Dec 16, 2023 at 5:10 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    Mornin 60+
    Nice. I love old buildings and seeing how they built them so they last hundreds of years. Got to work on my dads old building in Portsmouth a while back, the beams on the 3rd floor were exposed and each once was hand chiseled and each part of the trusses were stamped with a Roman numeral to match the cross beams. Evidently, they built everything on the ground, marked it, disassembled, carried it up then reassembled up there. Really cool.
    I still get up within a 30 minute window of what I did for decades, even 5 years after retiring….
    JGO, 06Tacooo, ImpulseRed008 and 10 others like this.
  13. Dec 16, 2023 at 5:51 AM
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    Been retired for 23 years. Still get up long before the sun. Actually I enjoy it even more. Summers we sit on our East facing screened porch having coffee and watch the world coming to life. Evenings we are back there with a glass of red wine as the sun sets.
    Enjoy your retirement and don’t waste a day because you can never get it back!
  14. Dec 16, 2023 at 5:53 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Can’t wait until my wife retires.:thumbsup:
  15. Dec 16, 2023 at 5:56 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Sorry for your loss.
  16. Dec 16, 2023 at 5:58 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    So sorry for your loss.
  17. Dec 16, 2023 at 6:14 AM
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    Good morning trouble makers.
  18. Dec 16, 2023 at 6:16 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    You never know what’s going to happen when those meds kick in.:D
  19. Dec 16, 2023 at 6:42 AM
    Travlr
    Middle'a Utah
    We've made a point of changing habits set by societal norms while working. Changes include two meals a day instead of three, 10ish AM and 5ish, and earlier to bed and earlier to rise. Bed when we are tired instead of any specific time. Sometimes up in the middle of the night and then back to bed. Screw the work habit... there are no rules. We even have dinner for breakfast and breakfast for dinner. Nachos in the morning!
  20. Dec 16, 2023 at 6:43 AM
    Travlr
    Middle'a Utah
    Safe travels...
