60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Jan 3, 2024 at 11:29 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    We have radiant in floor heating in the basement (concrete poured over the lines) and main level of the house (Lightweight concrete poured over the lines) and radiant baseboard heat on the 2d floor. The boiler heats the water for the heating system and also for the water heater. The water heater just maintains the temperature after the water is delivered from the boiler.
    Oldie2007 and Travlr[QUOTED] like this.
  2. Jan 3, 2024 at 2:10 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    learn something new every day.... gas hot water heater has no such animal.... pretty sure code here would require a plumber putting it in. I will ask next time they are here.
    and my phrase of a Google question gets:
    Expansion tanks are required by code in all new water heater installations in closed systems. A closed water system uses check valves, backflow prevention devices, pressure-reducing valves, or other devices on the supply line to prevent water from being sucked back into the municipal water supply.Nov 30, 2023
    Mine is NOT a closed system ....
    ndoldman59 and Travlr like this.
  3. Jan 3, 2024 at 2:37 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    That's interesting. Pretty sure mine's not closed either. So do you really need one?
    Oldie2007[QUOTED] likes this.
  4. Jan 3, 2024 at 2:42 PM
    Oldie2007
    Kurt
    Lockhart, TX
    The answer is probably it depends. Any expansion in the system has no where else to go without one, so you "could" suffer other damage. I do not have that experience, or expertise, but I understand the premise.
    We have a contract service for Heat/AC/plumbing, so next time they are here (always want to sell us something), I will see what they have to say. I like them, but their service guys are somewhat obligated to see what they can upsell.
    Travlr[QUOTED] likes this.
  5. Jan 3, 2024 at 2:51 PM
    Travlr
    Middle'a Utah
    Just to put it out there... if it does what I think it does, it has a rubber diaphragm in it to take any sudden surges in pressure and make them less stressful. Similar to the pressure tank on a well system. Well tanks need to be bled out once in a while so the bladder doesn't rupture or become waterlogged, which means they don't work. Is there any kind of bleeding system on the expansion tanks? That might keep it from having to be replaced so often.
  6. Jan 3, 2024 at 4:50 PM
    TCB2020
    TCB2020 Well-Known Member
    2020 Tacoma TRD Sport
    None
    Hot water and radiators. Generally not steam as the domestic hot water is supplied by the same boiler that serves the radiators.
  7. Jan 3, 2024 at 5:40 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Evening all:
    In my case, the furnace provides hot tap water and hot water for the baseboard heat.
    ndoldman59, Sprig and Oldie2007 like this.
  8. Jan 3, 2024 at 6:24 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I have never had one. Both in Arizona and Tennessee. Maybe it is related to hot water heat.
  9. Jan 3, 2024 at 6:50 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Dumb thought, there is a difference between a BOILER and a HOT WATER HEATER. Not that codes would know.... but if you have a closed system, at least I can understand the fundamental.
    ndoldman59, mit88 and Sprig like this.
  10. Jan 3, 2024 at 6:58 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Never had a boiler in any house I've lived in (as an adult - don't know about as a kid). But then again mostly have lived in AZ, NV, Southern CA, and SC. Heat pumps.
    Sorry. Have had some great delivery guys and some not so good ones....
  11. Jan 3, 2024 at 8:30 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    At the same time, they wonder why they can't keep good employees...
  12. Jan 3, 2024 at 8:55 PM
    OldSchlPunk
    Rich
    East Central Wisco
    We got a new boss a couple of weeks back. Today he had his first safety meeting. Among the topics was the mandatory lunch break that none of us take. He says we need to take it right in the middle of our busiest part of the day. Nobody's happy, nobody wants to lose customers or listen to those that are pissed off because we couldn't make it there in time (I'm an LTL truck driver).
    I'm pretty sure retirement just moved up from April to Feb. I'm so tired of this shit.
  13. Jan 4, 2024 at 1:24 AM
    Devious6
    Mark
    Good morning fellow Porchatonians!!!
  14. Jan 4, 2024 at 2:26 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Morning kids :hattip:, they have been talking winter weather in the forecast, blasphemy, it’s January in Michigan.
  15. Jan 4, 2024 at 4:05 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
  16. Jan 4, 2024 at 4:14 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    It is a plumbing code thing here in my county. It is supposed to control any surge in water pressure due to the hot water expanding and possible causing a hot water heater failure. Yes, there is a drain valve on the expansion tank. All new hot water heater installations have to be inspected by the county and the install has to meet code. Just another way county can increase fees. I doubt if the fees cover the inspector's time.
    Good morning. Sad day yesterday. My buddy Amigo, family cat, passed. He was 19 and a half years old and was a good friend. He has been getting worse the last half a year and yesterday he coud not climb out of his bed. We took him to the vet with the reality of putting him to sleep but, true to an Orange Tabby, he passed on his own terms in the vet's office.
  17. Jan 4, 2024 at 4:33 AM
    TCB2020
    None
    Yea, losing a pet can be tough. We lost our rescue cat over 2 years ago and we just can't bring ourselves to get another. 19.5 years is a good run.
  18. Jan 4, 2024 at 5:05 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    My condolences on your loss. One of our little guys just required emergency surgery for a blocked urethra due to crystals in his urine. He's only 3 and the sweetest cat I've ever had so we opted to get him the surgery. Following that he needed to go to a 24 hour vet hospital for monitoring and blood work every 8 hours to watch for kidney damage. Looking good and back home now but more money than I've paid for several cars in my life.
  19. Jan 4, 2024 at 5:07 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    yes, yes it was, a helluva run..condolences..
    95SLE, 06Tacooo, ndoldman59 and 2 others like this.
  20. Jan 4, 2024 at 6:17 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    So sorry to hear on your loss , 19.5 yrs is a long time
