60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Jun 3, 2024 at 6:31 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Good Morning everyone :hattip:
    95SLE, jwctaco, Ridgewalker1 and 5 others like this.
  2. Jun 3, 2024 at 6:32 AM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Morning all:
    :drool: on your friends Camaro Kurt! :thumbsup:
    So much for the tech advice on the computer! :rolleyes:
    LOTS of posts said to replace the small secondary screw on a Holley base plate with a 10-32 allen head MACHINE SCREW so that you can tune the secondaries without having to remove the carb every time, one problem, the lever on the linkage hits the head of the screw and won't allow the secondaries to fully open unless a really long one is installed, which was never mentioned. OK, plan B, ordered some 10-32 SS SET SCREWS that use the allen head wrenches, those will work no matter what length, no one mentioned using them, maybe there's a reason, I'll find out shortly! :rolleyes:
    95SLE, jwctaco, 06Tacooo and 6 others like this.
  3. Jun 3, 2024 at 6:58 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Have you checked with Holley https://www.holley.com/products/fuel_systems/carburetors/
    They have small parts such as baseplate screws and throttle plate screws available . Just call their tech line and speak to a Holley tech person . Do you also have the carb list # or the cfm rating ????
    Ridgewalker1, Sprig, mit88 and 2 others like this.
  4. Jun 3, 2024 at 7:18 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Good advice @US Marine ! And good luck @boatswain !
    :pccoffee: Good Morning Porch Pals & Sue! It was good to get to a show again, even if I did lose my friend while we wandered. I was amazed I couldn't even locate his car - how do you miss a Burnt Orange 300Z?
    Fiascos continue on the home front; the whole pool light will be replaced, and I'm putting a 12V in as a replacement (I hope). I will have to install it's transformer/remote in a new box by the pool controls, but wire is wire, and that part should not care. So, the LED replacement bulb goes back. This one has the same remote, but ALSO a phone app, so if RF doesn't work from the remotes, I hope that should. Diving board comes off this afternoon to get at wiring.
    And wife has Spectrum coming at 11 because our internet speed has gone to trash. It takes a minimum of 1 minute to upload each of those show pics, which is why it takes so long.
    JGO, Ridgewalker1, Sprig and 4 others like this.
  5. Jun 3, 2024 at 8:46 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Thanks for your patience in uploading the pictures; they bring back lots of memories to many of us. :hattip:
    JGO, US Marine, 95SLE and 6 others like this.
  6. Jun 3, 2024 at 10:34 AM
    boatswain
    carl
    palmerton,PA.
    The stock screws are available, using the stock slotted screw requires the carb to be removed in order to adjust the secondary throttle plates. with the minor mod that I am doing I can adjust them all I want without removing the carb every time. I think the original screws are made of steel, the one we just drilled out looked like a factory steel screw, once there are in there for quite a while without being moved they are almost impossible to turn for adjustment or removal.
    I have 2 #3246 780cfm Holley's that are correct for the car, one of them is on the car, 2 #3417 830cfm Holley that is a NASCAR carb and also a correct carb for the car, and 1 #3418 Holley 830cfm that was used on some of the 427 corvettes, I plan on changing that secondary screw on all of them.
    If I use short 10-32 allen head set screws I could tuck them up in the base plate like the originals and still access the head with an allen wrench, with longer ones I can have as much as i want sticking out below the base without the secondary linkage hitting it.
    One thing, the original slotted Holley screws are slightly spread apart at the screw slot so they bind and don't move easily, I will need to put a MILD thread locker on the screws that I am replacing them with, NBD and will probably help stop galvanic corrosion between dissimilar metals, also going to SS screws should also help.
    Don't forget, I'm playing with 50+ year old carbs, not new ones! :rolleyes:
    95SLE, 06Tacooo, mit88 and 4 others like this.
  7. Jun 4, 2024 at 3:01 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    ndoldman59, Oldie2007, dand and 4 others like this.
  8. Jun 4, 2024 at 3:16 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Good morning all. :pccoffee:
    ndoldman59, Oldie2007, dand and 5 others like this.
  9. Jun 4, 2024 at 4:24 AM
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    Another hot day…7* above average with tomorrow 18* above average! Hot and dry!
    Taking the granddaughter to the range today. Need to get her shooting well prone at 300-400 yards before January in prep for her West Texas Aoudad hunt.
    Got a lot done in the yard yesterday after my workout. Exhausted last night.
    Everyone stay busy in your new era of life. Get those dreams done and don’t waste a day!
  10. Jun 4, 2024 at 4:27 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning 60+ :hattip:
    ndoldman59, dand, jwctaco and 3 others like this.
  11. Jun 4, 2024 at 5:01 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Good morning. The Avalon is getting new tires today. Went with Michelin Cross Contact 2, 18-245-45.
  12. Jun 4, 2024 at 5:13 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Good Morning :hattip:
  13. Jun 4, 2024 at 5:49 AM
    boatswain
    carl
    palmerton,PA.
    Morning all:
    Needed to edit my last post, I have two #3417 Holley's, not 1, never enough carbs! :D :facepalm:
    The #3246's are readily available, the #3417's are rare.
  14. Jun 4, 2024 at 6:22 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Good morning. :oldglory:
  15. Jun 4, 2024 at 7:08 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I learned about this modification at a Holley sponsored tuning clinic - in 1969 in Springfield, Mo at the old "Mother's Speed Shop". Works perfectly.... there were "tuners" of the day that espoused DRILLING HOLES(!) in the secondary plates as a means of adding idle air while the primary blade was at its "sweet spot". If you check - there are many intake manifold castings that already have a relief directly under the screw location. I'm lazy in my old age and simply use a longer machine screw with the head cut off to replace the slotted factory part - leaving enough protrusion under the throttle plate to quickly adjust it with needle nose pliers.
    I have found it difficult to convince various individuals that the screw is there - and even more difficult to keep newbee's from messing with the primary screw while you get the engine into idle range... with the primary blade positioned on the transfer slot.
  16. Jun 4, 2024 at 7:28 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Here's my carburetor that's on my 427sbc , it's a Holley Ultra XP 950cfm from AED performance carbs . It was custom built to my specs and wet flow dynoed to over 1000cfm
    JGO, 95SLE, Ridgewalker1 and 7 others like this.
  17. Jun 4, 2024 at 8:00 AM
    Oldie2007
    Kurt
    Lockhart, TX
    :annoyed: Good Morning Porch Pals and Sue! Long day at the internet world. And more to recover. Too much to do today.
  18. Jun 4, 2024 at 8:13 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Good morning everyone, from the lake.
    Last night's sun setting
    JGO, 06Tacooo, ImpulseRed008 and 11 others like this.
  19. Jun 4, 2024 at 9:12 AM
    dand
    Dan
    Newport News VA
    Beautiful!
  20. Jun 4, 2024 at 9:21 AM
    mit88
    Planet earth
    Stunning scenery! :101010:
