60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Aug 15, 2024 at 7:06 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Thanks for the info Rich. Having said goodbye to several of my 4 legged kids I know her pain.
    mit88, US Marine, 1buzzbait and 4 others like this.
  2. Aug 15, 2024 at 7:06 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Don't we all?
  3. Aug 15, 2024 at 7:13 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Carl, I didn't post in here.... I was going to... just couldn't post it again.
    Phillip, I missed the post about your granddaughter - hope she recovers soon
    Carl, hope you got your latch all fixed up. is there a way to put a washer on the inside and sammich the door between the handle and washer?
    Yes, she's gone :rant: The worst part - I took her to the emergency vet to be put down, I wasn't sure if she was in pain... and didn't want her to suffer. We get there and she is non-responsive, she didn't move a muscle when they put her on a stretcher taking her out of the back of OB - you'd figure a vet and vet tech would recognize the signs she doesn't have much time left and they wanted to know if I wanted them to do blood work and try and treat her. Then the vet told me she was incontinent - REALLY??? You mean all the blue pads I changed was for nothing?!?!?! All the pee wasn't pee at all. Sorry.....
    No, they didn't mis read anything unfortunately
    thanks
    :wave: evening boys
    mit88, JGO, US Marine and 5 others like this.
  4. Aug 15, 2024 at 7:18 PM
    ImpulseRed008
    Susan
    SC
  5. Aug 15, 2024 at 7:19 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Sorry...
  6. Aug 15, 2024 at 7:48 PM
    Sprig
    Ken
    It perfectly normal to be nervous , we all get nervous, concerned, scared prior to surgery. The stents are no big deal. Almost every time they perform kidney surgery to remove stones (which is a common and frequent surgery) stents are placed. Either temporary or permanent stents. I’ve had them myself. Don’t know for sure but I assume it likely they will use laser lithotripsy to breakup and remove the stones. May use a different technique. It’s a quite common surgery and a fairly safe procedure. I’m not sure how Parkinson’s affects or complicates the surgery. Grill your doctor with questions and your concerns. Knowledge will quell many of your concerns. Ask how many of these procedures your surgeon has done. You don’t want a surgeon who has only done a couple such surgical procedures. Finally think positive, the power of positive thinking can get us through almost anything. Prayers sent your way.
  7. Aug 15, 2024 at 7:53 PM
    Sprig
    Ken
    So so very sorry Sue. I know the feeling of your loss, I know the pain and sadness. Just can’t find the words to adequately express myself.
  8. Aug 15, 2024 at 7:53 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    words later....
  9. Aug 15, 2024 at 9:45 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    :wave: Sue!
    The latch is a rectangular piece of steel with a 1/2" hole in it that fits onto the 1/2" shaft on the door handle, a set screw or bolt holds it in place on the shaft and allows for adjustment if needed, that is IF I CAN GET THE DARN THING LOOSE!
    There is a shaft collar on the handle on both the inside and outside of the door that keep it in place, that isn't the problem, it's the part that goes against a small ramp inside the stove that tightens and applies pressure to the door so it seals against the gasket.
    Possibly, threading the end of the 1/2" rod and using nuts and lock washers to hold the latch in place instead of a set screw would work---MAYBE, plus that would be more work!
  10. Aug 15, 2024 at 10:05 PM
    ImpulseRed008
    Susan
    SC
    More work now, less work later? :notsure:
  11. Aug 16, 2024 at 3:57 AM
    Jim727386
    Jim727386 Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    Good morning all. Sorry for your loss Sue. Prayers for successful kidney procedures Chuck, and know "The One who calmed the sea" is there to bring peace to you.
    May we all have a safe and blessed Friday.
  12. Aug 16, 2024 at 4:09 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Whew, It looked heavy. I know the frames can be lighter and stronger, but glass is glass, and it is heavy. There is a lot of glass in that window. Working on unique projects is always exciting and fun to do. That window looked like a lot of work but when done the satisfaction when finished had to feel good.
    Susan and I are friends on Facebook. I saw her post yesterday morning. It was not a fun post to read.
    Good morning. Today we are off to my sister's beach home for a weekend of relaxation. When we get home on Monday I will need to replace the expansion tank on the hot water heater. O fun o joy, I just love to do plumbing.
  13. Aug 16, 2024 at 4:32 AM
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    Friday? Another Friday? Only 5 so far this week! What a grand life!
    As a retired mechanical engineer, I’ve almost always done my own vehicle work. From simple mods to engine overhauls and pull and replacement. Sadly in the last couple of years if my hands get close to steel, my hands lose flesh and blood! It’s like the steel attacks my flesh! I’ve tried Mechanix gloves, neoprene gloves, all sorts, but to no avail. BLOOD SUCKING STEEL! Even things as simple as oil changes seem to damage my old hands!
    Weekend trip prep tasks: truck- load camping gear, load fishing gear, check all recovery/tire repair gear, check fluids tires, etc.; Casita-flush water lines and fill water tank half way, check propane, light and cool down refridge, load clothes, schedule meals & buy food, make veggie platter for grandson & bud, check tire pressures, etc.; House-make certain bird feeders are all full Sunday night, rinse and refill birdbath Sunday, print out map with dates & locations for my lady, one more chlorox wipe cleaning of house before cleaning ladies show on Monday.
    I think that’s all I need to get done before my Wind River Range escape. 6 days alone with fish and maybe see some wildlife. Weather-70s days and high 30s to low 40s nights! NICE! Wish you all could join me for a week of fishing and wildlife spotting!
    JGO, 95SLE, 06Tacooo and 7 others like this.
  14. Aug 16, 2024 at 5:19 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Wow! Sounds like a WONDERFUL trip you have planned. Please share pics when you return. Safe travels and safe adventures!
    Sprig, Oldie2007, US Marine and 2 others like this.
  15. Aug 16, 2024 at 6:24 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Good Morning :hattip:
    Strong to severe t storms in the forecast for my area
    Ridgewalker1, Sprig and Oldie2007 like this.
  16. Aug 16, 2024 at 7:10 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    The surgery I'm going to have is called Percantaneous Nephrolithotomy . They insert a scope into my lower back through small incisions then cut open each kidney and remove the stones
    For this surgery I'm placed into a prone position on the table . My Anesthesia doctor is concerned that being I'm in a prone position and having Parkinson's my breathing can become an issue as this surgery is 4-5 hours long
  17. Aug 16, 2024 at 7:12 AM
    OldSchlPunk
    Rich
    East Central Wisco
    The frame alone was tough to move around. We didn't put the glass in until the frame was in and squared-up. I can't take any pride in the job. My buddy's the carpenter and came up with all of the brainpower to overcome the rot we found in the support framework. I always say: Give me a piece of wood, I'll burn it for heat. Give me a piece of metal, I'll make you something.
    mit88, JGO, US Marine and 7 others like this.
  18. Aug 16, 2024 at 7:51 AM
    Sprig
    Ken
    You are a Marine. If anyone can kick Parkinson’s ass and overcome the kidney problem, you can. Trust in and believe in God, you are going to be ok.
  19. Aug 16, 2024 at 8:11 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly-09 Primo XL custom cover, D-plates, divider, raised grates
    ^^ THIS ^^
  20. Aug 16, 2024 at 3:06 PM
    Oldie2007
    Kurt
    Lockhart, TX
    You got it Chuck! They will ensure your proper breathing if interrupted, I am sure. And all those stones gone? Will be comfortable to sit in your rumble car! :thumbsup:
