60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Jul 15, 2025 at 12:13 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Not an expert on small engines but have worked on a number of them and was a fair shade tree auto mechanic. Even though ran all the gas out of it there’s often a tiny bit of residual in the carb that turns to varnish like and gunk after long no use. I would pull the carb and clean the crap out of it or possibly get a new carb. Just my 2 cents worth. I had the same thing happen on a Honda generator. Thoroughly cleaned the carb, now starts every time and runs til out of gas.
    mit88, 95SLE, 06Tacooo and 6 others like this.
  2. Jul 15, 2025 at 1:12 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    "Pro-Tip" ethanol free fuel, should correct fuel related issues in the future...I also leave my Honda gennie, lawnmower, power washer, atv FULL of ethanol free fuel all year, all the time. No carb issue's anymore....
    mit88, 95SLE, 06Tacooo and 4 others like this.
  3. Jul 15, 2025 at 1:38 PM
    Sprig
    Ken
    And one other thing, if it sat for 5 years change the oil, put a new spark plug in it and if it has a fuel filter get a new one. It’ll run like a champion (pun intended)
  4. Jul 15, 2025 at 1:47 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Thanks Paul, I also saw that some do run it at 50:1.
    I have a plan :rolleyes:, if it supposedly works well at 100:1 or 80:1, and also works well at 50:1, to make it easy I will just add 2oz of it to a gal., or 1oz to a half gal. and forget about the tenths to make it easy to measure. That would put the mixture above 50:1 but less than the 80:1 and should work just fine---- by my logic! :)
    Travlr, I would be looking at the carb and anything carb related also. I don't know what kind of fuel line generators have on them, but ethanol fuel is notorious for destroying boat fuel lines which causes all types of problems, might take a look at that also.
  5. Jul 15, 2025 at 2:05 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Yeah, I leave my lawnmower full of gas and have never had an issue. Maybe running it out to store it was a mistake...
  6. Jul 15, 2025 at 2:53 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Full of what gas? That is the larger question.
    1buzzbait and johneman[OP] like this.
  7. Jul 15, 2025 at 3:21 PM
    Travlr
    Middle'a Utah
    Pump gas... Maybe that's the smaller answer...lol
  8. Jul 15, 2025 at 3:23 PM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    Well I picked up thee Mr cool mini split last week from the trucking company.
    I made not of some damage to the boxes on the shipper. No damage was found inside, well packed.
    It comes with a template for locating the 3 1/2" hole and mounting screws.
    The inside unit will be offset so the large hole for the lines misses the studs.
    Here you can see the 3 1/2" hole. It will be covered by the inside unit.
    Mounting plate is leveled and mounted to the wall.
    Next step will be drilling the big hole. Here's the unit it will be replacing also, it only lasted 2 years. GE p.o.s.
    I'm still capable of doing diy stuff like this so I'm saving a ton of money. It'll be nice to have the full function of the window back too.
  9. Jul 15, 2025 at 3:30 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Ethanol 10% most likely is what I am getting at. Hygroscopic - absorbing water from atmosphere/condensation making a mess of fuel systems
  10. Jul 15, 2025 at 3:36 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Plus, alcohol is corrosive to jets and destroys many plastics.
  11. Jul 15, 2025 at 3:49 PM
    Travlr
    Middle'a Utah
    Yeah... and yet that mower is 17 years old and has never been stored without gas in it. I've been waiting for it to die for at least ten years, so I could get a chargeable one.
    So we are back to whether the generator is WORTH trying to fix.
  12. Jul 15, 2025 at 3:59 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    pull the plug, replacement may not be needed
  13. Jul 15, 2025 at 4:00 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    It’s the water that is hard on jets and thank goodness newer engines use alcohol resistant polymers- but not always. Fuel pump recalls come mind
    mit88, 06Tacooo, johneman[OP] and 2 others like this.
  14. Jul 15, 2025 at 4:06 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    no bueno,,, pump gas, for small, random use engine, if you can,needs be ethanol free, now that being said, it might be a challenge to find it, for example, i live in MD, Chesapeake Bay, Mighty Potomac, and their are only 3 ethanol free stations that I can find in the whole damn state.... worth the effort and you will pay more for it but........
  15. Jul 15, 2025 at 4:13 PM
    woodtickgreg
    Greg
    Michigan
    I get ethanol free fuel at a marina near me.
    1buzzbait, 95SLE, 06Tacooo and 2 others like this.
  16. Jul 15, 2025 at 4:41 PM
    Travlr
    Middle'a Utah
    Pretty obviously... not my experience.
    I've made a point of testing some of the advice I hear from people making money by giving advice, and that have become popular opinion. Saved a lot of money by doing so. What I've learned more than anything else... is that "cheap Insurance" is often the more expensive option.
  17. Jul 15, 2025 at 4:51 PM
    Radd
    Radd Well-Known Member
    Santa Cruz Ca
    2023 Tacoma TRD Offroad
    One reason you might want to watch the All-Star game. "Robot umpire"balls and strikes. A umpire still calls balls and strikes but each team gets two ball and strike challenges. The challenge result appears instantly on the jumbo Tron, it appears in a format just like when tv coverage shows the simulated pitch and the strike box.
  18. Jul 15, 2025 at 5:42 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Alcohol is listed in the Hazmat Tables, it's listed under Corrosives. Water doesn't bother brass, alcohol does. And within even the last 5 years or so, some motorcycles have had gas tanks melt because of higher alcohol levels in gas.
    Small engines aren't built to the same level as that in your car or truck. All small engine manufacturers warn to use E0 gas to this day.
    I've had three small engines (chainsaw, pressure washer and weed wacker) damaged in the last 2 years because I screwed up and used 87 octane gasohol for the premix. The pressure washer needed a carburetor, the chainsaw only needed a fuel line (a bitch to replace), but the weed wacker was destroyed.
  19. Jul 15, 2025 at 7:25 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I don't doubt your experiences. But it is the moisture. Absolutely agree on the E0.
    Alcohol IS listed as a 3 Flammable liquid, not under Corrosive 8 on the HazMat table
    https://www.ecfr.gov/current/title-49/subtitle-B/chapter-I/subchapter-C/part-172
    Yes, ethanol can corrode brass over time, especially in the presence of moisture, leading to issues like dezincification, where zinc is lost from the alloy. This corrosion can affect the integrity and appearance of brass components. And Yes, water can corrode brass. Also via dezincification, where the zinc component is leached out, weakening the brass over time.
    DRY (key word) ethanol in gasoline won't corrode brass, but the problem is it never stays completely dry because ethanol is hygroscopic, very much so. Hence the problem of storage, and gumbo and corrosion.
    mit88, 1buzzbait, US Marine and 2 others like this.
  20. Jul 15, 2025 at 8:01 PM
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    That is baseball.I think there is someone flipping switches turning players and whole teams on and off.Must be like golf.
