60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Oct 24, 2015 at 2:42 PM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    "Ears burning" is the way I heard it growing up.
  2. Oct 24, 2015 at 3:00 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :wave: evening folks :wave:
    Rear diff fluid changed, oil changed and old oil dropped off at recycle center :thumbsup:
    NMroamer and MQQSE like this.
  3. Oct 24, 2015 at 7:48 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Evening Sue! :wave:
    You still doing that yourself? Sounds like you been busy!
  4. Oct 25, 2015 at 3:56 AM
    Tacoma Mike
    Southern Maine
    This
  5. Oct 25, 2015 at 4:22 AM
    Tacoma Mike
    Southern Maine
    I don't have to worry. As Long as there a parking spot for her I'm all set. :yes::yes:
    I don't use the welder or torches very often but there against the wall waiting....
  6. Oct 25, 2015 at 4:38 AM
    Tacoma Mike
    Southern Maine
    Plugs, air filter, cabin filter lube doors and locks. Tire pressures. Wax. Fluid film.???????????????
  7. Oct 25, 2015 at 6:59 AM
    ImpulseRed008
    Susan
    SC
    Yes, why you ask? Am I not supposed to?
    Plugs and air filter sitting on the counter waiting for another day. Usually takes me longer to do stuff. Don't like starting unless I know I can finish. What do you use to lube doors?
  8. Oct 25, 2015 at 7:48 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I use white lithium grease on hinges/slides/latches/locks ... Silicone the rubber door seals. :notsure:
  9. Oct 25, 2015 at 9:41 AM
    boatswain
    carl
    palmerton,PA.
  10. Oct 25, 2015 at 9:59 AM
    ImpulseRed008
    Susan
    SC
    :oops: That's a very nice compliment. Thank you!! :thumbsup:
    I have the number to call mosquito control in the morning... Have to try and get rid of these things... You know a 'sketer is big, when you can feel it land on you :eek:
  11. Oct 25, 2015 at 10:33 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I use this stuff like lotion on all exposed areas during Summer skeeter season; used it for over 10 yrs now. It works and doesn't have the deet chemical odor of a lot of the repellants. :notsure:
  12. Oct 25, 2015 at 11:06 AM
    ImpulseRed008
    Susan
    SC
    :thumbsup: thanks I have some bands which use citronella and they seemed to work. But don't wear them in the house. Half the ones I've killed have had blood in them... when the dogs go out, they get covered in the stupid things.
  13. Oct 25, 2015 at 11:15 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I literally use it like regular lotion, put it on after coming out of the shower in Summer so I can't forget; else I wouldn't think of it until it was too late and I was already getting bit.
  14. Oct 25, 2015 at 11:46 AM
    Tacoma Mike
    Southern Maine
    I don't like using white spray lube or anything white. Some of them dry and looks like crap and don't penetrate. Then it's tuff to clean. Some are super anal about that. I use stuff like safety clean rust penetrant. I also use ff If the hinges free and clear. WD40 sucks. Any "dry" lube sucks. Up here you need penetration in order to dissolve the rust inside the pivots.
  15. Oct 25, 2015 at 11:52 AM
    ImpulseRed008
    Susan
    SC
    ff?
  16. Oct 25, 2015 at 11:55 AM
    Tacoma Mike
    Southern Maine
    I commend you on your Tacoma maintenance. Need to make a vid showing you doing it to bring some of the so called experts on here down a few notches. The shit is gets deep from time to time.
    ImpulseRed008[QUOTED] likes this.
  17. Oct 25, 2015 at 11:55 AM
    Tacoma Mike
    Southern Maine
    Fluid film to keep moisture out
  18. Oct 25, 2015 at 12:02 PM
    ImpulseRed008
    Susan
    SC
    :anonymous: It has been a while since I lubed the hinges.... added to list. Thanks for the reminder
  19. Oct 25, 2015 at 12:07 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  20. Oct 25, 2015 at 12:10 PM
    Tacoma Mike
    Southern Maine
    Spent all day doing winter prep. Tractor needs the chains and extra 60 pounds of weight strapped to its ass. Need to pick up the yard and get the blowers out. Next week. Harley going night night in a few min.
    95SLE likes this.
