60k Fluid Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyzmyss, Aug 5, 2010.
  1. Aug 5, 2010 at 11:21 PM
    kyzmyss
    kyzmyss [OP] Well-Known Member
    NorCal
    07 Dbl. Cab TRD Sport 4x4
    Hi Everyone,
    So I am thinking of taking the plunge and doing the 60k service myself. I figure I could save some money instead of giving it to the stealership....
    What fluids do you recommend for the Front/Rear Differential (incl the limited slip)?
    What about the AT fluid? I know this doesn't need to be changed but would it not be good to do this now?
    Was thinking Mobil 1 but not sure which product of theirs is best for our trucks...
    I have an 07 4d Long Bed 4x4 Taco...
    Any help is appreciated.
    Thanks in advance.
    Kris
  2. Aug 6, 2010 at 7:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  3. Aug 6, 2010 at 10:08 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    For the AT fluid I think you should use only the Toyota fluid. I honestly don't know where to get it if not the dealership. The process is a bit involved for changing it since you need to measure the temp of the fluid to set the level in this semi-sealed unit.
    I read where one guy just drains it (3 qts) every 15K, puts exactly the same amount back and never worries about the temp thing. Makes all the sense in the world so long as you're getting the same volume back in.
  4. Aug 6, 2010 at 11:03 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The AT fluid is the only thing I'd have the dealer perform. They should flush the torque convertor when they change it, not just drain and refill. Basically run the fluid through the lines backwards to clean things out.
  5. Aug 6, 2010 at 11:22 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i used Redline in the diffs and transfer case..no issues.
  6. Aug 6, 2010 at 11:42 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's true about getting the TC fluid being important when fluid's never been change. The strategy of doing the 15k change of 3 qts, though, is that you never let the ATF get bad as 1/4 is being frequently freshened.
    I've done pretty much the same with my Maxima but I get 1/2 the fluid by just draining it so I do it every 40K or so. It's worked great and the fluid stays a nice bright red, not the blood red when it's old.
    Are you sure they reverse-flush the fluid through the lines? I don't know if that is safe through the valve body and might not go everywhere any way if there's one-way valves.
  7. Aug 6, 2010 at 11:46 AM
    Pugga
    Massachusetts
    I thought I had heard they reverse flush it, could be wrong on that part though. My old man used to be a mechanic and he's the one who told me about it when I was going to change my transmission fluid myself on my first truck. That being said, I was pretty young and probably doing the classic teenager tune-out. At least I caught the important part though!
