60k mile Timing belt replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Styx586, May 11, 2012.
  1. May 11, 2012 at 10:23 PM
    Styx586
    Styx586 [OP] Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    So my wife took my truck in to the dealer today to get the 60k service done, and they said it needs a new timing belt and water pump and they quoted $600+. I did a little research here on TW and found out that when replacing the TB its recommended to replace all the other belts, water pump, etc. But does it really need to be done at only 60k miles? Seems to me maybe they're just trying to get more money out of me? I'm out of the states right now so i can't really check it out myself... any suggestions?
  2. May 11, 2012 at 10:33 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I think it says to change it every 90k. i might be wrong on that though. i bought my truck with 136k and it had not been changed, got it done with all other belts at 139k. I did not have the water pump done since they said it would be another 400.
  3. May 11, 2012 at 10:35 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    90K is the regular interval for that
    And they can inspect it all they want, but the wear wont be apparent until it breaks
    the good news is that if it breaks...it does no damage to your engine
    Tell them to buzz off and you can handle it when you get home
  4. May 11, 2012 at 10:46 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    400 extra for the water pump? It is like 7 bolts once the timing belt is off and the new pump, which might cost $100. They were ripping you off.
  5. May 11, 2012 at 10:47 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Did you get your water pump replaced when you did yours? Toyota told me that mine was leakin the slightest amount. Ive looked for any leaks cant find any
  6. May 11, 2012 at 10:49 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Shoot sorry you are right. they told me once they had the timing belt off it would be 130. i Think 400 was the price if i did it later. but i figured ive never seen any leaks and didnt wanna be broke for a week so i told them not to do it
  7. May 11, 2012 at 10:56 PM
    JDMcQ
    That makes more sense. Most people do the water pump while it is apart. I would hate like hell to spring a leak 2 days after putting it all back together. they don't last forever.
  8. May 11, 2012 at 11:01 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Yeah i know, I would have done it if i had the money at the time. i didnt wanna have to walk to work for a week though haha
  9. May 11, 2012 at 11:02 PM
    JDMcQ
    I can certainly understand.
  10. May 11, 2012 at 11:30 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    The leak is pretty hard to spot
    I changed mine when I changed my timing belt...I forget what all I changed but those were the 2 major things
    It only took me and another member about 4 hours to knock it out
  11. May 12, 2012 at 4:40 PM
    jodjr
    jodjr Well-Known Member
    New Hampshire
    03 Tacoma V6
    I have 50k miles on my 2003 and it was in for a frame replacement. I had them change my timing belt and they (dealership) said it was due because of the age not the mileage. They wanted to change my water pump but it was swapped out @ 12k miles and covered by Toyota years ago.
    So bottom line is the age of the truck also comes into play on the belt replacement.
    PS : They said my water pump was leaking too...turned out to be bad hose clamps.
  12. May 12, 2012 at 5:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Water pump is usually a good idea on the TB change. Since the TB has to come off to replace the WP the labor charge is typically the same. The water pump is only $100 or so more. Okay, the pump doesn't need replacing at 90k with the belt... but how confident are you that the pump will go 180k to the 2nd belt replacement?
    But be careful. I did mine myself on my '03 Tundra's 4.7. I called a few dealers and got quotes ranging from $600 to $1700. Those charging $1700 were using book-rate for EVERY item I requested, which was:
    Timing belt
    Water pump
    Tensioner
    Thermostat
    Doing all of these items takes a grand total of 10 minutes longer than doing the belt alone, but these dealerships were charging book rate as if I brought the truck in and requested 4 separate jobs.
    BTW: It took me 6 hours using hand tools, including an hour driving to the dealer to get the right serpentine belt after attempting to install the wrong one.
    Total was about $350 for parts, including the above, and replacement of all belts, hoses, and fresh coolant.
  13. May 13, 2012 at 9:14 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's set @ 0 with OME 883x coils up front . Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. 4 Runner Trail 17in. Wheels.
    Rule of thumb is do the water pump and drive belts the same time as the timing belt . They are going to have it all apart anyways. Saves you labor coast later. My understanding is the timing belt should be done at 60k. The age of the truck is also true. This is what I do! :D
  14. May 14, 2012 at 10:23 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Just found out over at Ttora that a valve inspection at 60k is recommended! Has anyone had there's checked at 60k? 100k? 150k? were any of the valves out of spec?
  15. May 15, 2012 at 9:01 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Do the belt and water pump at 90K miles, if you skip the WP you may be sorry, the whole job needs to be redone to change it later, preventative measures are ALWAYS a good idea.
    BTW if you guys need any service work including Timing Belts, I was a Toyota master tech and work from my home shop in Vista working on about 90% Toyotas, I can get OE parts and can save you lots of cash on the work and ti will be done top notch..
  16. May 15, 2012 at 9:29 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Ditto, the belts are 11 years old now. They can harden and crack. Typical menu of items:
    Timing belt and tensioner
    Water pump
    Camshaft and crankshaft seals
    Accessory belt and tensioner
    Pulley and tensioner bolts replaced with new ones
    The last one is important - a co-worker had a tensioner bolt shear off 200 miles after a timing belt change, and had to do it over again.
  17. May 15, 2012 at 11:21 AM
    x2468
    Vermont
    Anyone get their valves checked?
  18. May 15, 2012 at 11:42 AM
    JDMcQ
    Never heard of that.
  19. May 15, 2012 at 11:53 AM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Its in the service manual interval to inspect valves every 60k.
    I posted this in another thread... Some will say do it, some will say wait til 90k during timing belt change, some will say wait until you run into an issue, some will say never had a problem.
  20. May 15, 2012 at 11:55 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    i assume you have a v6?? i have the 2.7 and 168k miles pretty sure it has the original chain
