60k Service/Transmission Fluid Change - Only Genuine Toyota WS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kgorczyn, Dec 20, 2012.
  1. Dec 20, 2012 at 9:54 AM
    kgorczyn
    kgorczyn [OP] Member
    Central FL
    09 PreRunner 2WD
    Hello.
    I'm new to the forums - think I will be hanging out here quite frequently. Great Community!
    My GF has a 09 Tacoma V6 PreRunner 2WD. She is about to hit 60k miles and the dealer wants over $600 to do the service (60k Service)
    For the transmission fluid - do we need to use the Toyota Fluid or has anyone been running any Mobil/Valvoline/etc fluids from the local auto zone or what not?
    What about Differential Fluid?
    Any other tips for the 60k service?
    Thanks,
  2. Dec 20, 2012 at 9:57 AM
    travel_taco
    travel_taco Gentlemans Sausage
    CO
    09 Rust Bucket
    anti-fuel saving mods
  3. Dec 20, 2012 at 10:04 AM
    kgorczyn
    Central FL
    09 PreRunner 2WD
    Thanks for the info. Great Collection.
    Now just need info on the transmission fluid as it's not in that list :)
  4. Dec 20, 2012 at 10:09 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    My dealer told me that the WS fluid never had to be changed and that I had a sealed transmission. That bothers me an when I asked how much to change it 'just because' they said $500-$600
  5. Dec 20, 2012 at 10:11 AM
    travel_taco
    CO
    09 Rust Bucket
  6. Dec 20, 2012 at 10:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Use Toyota's fluid for the transmission.
    For the differential, use the weight specified in your Owner's manual but you do not need to use Toyota fluid for that. Mine takes 75W-90 and I used Valvoline synthetic. I'm not sure if yours takes the same weight or not.
    I bought the Toyota plugs for my 30 and 60k mile service and changed them myself. It's a pretty simple process and there is a writeup on how to do it.
    The rest of it is pretty self explanatory, air filter, cabin air filter, grease u-joints (not sure if you can on the 2wd), rotate tires, change oil and oil filter.
  7. Dec 20, 2012 at 10:23 AM
    kgorczyn
    Central FL
    09 PreRunner 2WD
    Do you guys suggest a transmission fluid drain/refill or a full blown flush?
  8. Dec 20, 2012 at 10:32 AM
    Pugga
    Massachusetts
    I do a drain and refill at 50k miles but I've owned it since new so I know it hasn't been beat on. If it was used, I might go for the full flush.
  9. Dec 20, 2012 at 10:42 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I was told once that a full flush not necessary just flush/fill. I have 124k on mine with original fluid. pondering what to do with my AT. want to do something soon.
  10. Dec 20, 2012 at 10:56 AM
    kgorczyn
    Central FL
    09 PreRunner 2WD
    Thanks guys... for those that did the drain/refill how many qts? If it makes a difference, this truck has the tow package.
    I believe the full flush is like 13-14 qts.... at $8 a qt that adds up quick!!
  11. Dec 20, 2012 at 1:40 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    I have 94,000 on my taco. I bought it new, and I tow a boat almost every weekend in the sumer. I just had the tras fluid changed (full flush hooked to the machine). I know the guys at the dealership very well (I work on their archery equip) so they always shoot me straight answers.. they said the fluid was starting to get a bit dirty and it was definatly tme to change.
    I paid $245 for the trans fluid change and a oil change / full car inspection.
  12. Dec 21, 2012 at 6:11 AM
    kgorczyn
    Central FL
    09 PreRunner 2WD
    Have you guys that have done this also replaced the Tranny Filter?
  13. Dec 21, 2012 at 6:25 AM
    Pugga
    Massachusetts
    No, and I wouldn't bother with it. It's just a metal mesh screen and it's buried inside the transmission. It's not meant to be a servicable part so I wouldn't mess with it unless you feel you have a good reason to.
  14. Dec 21, 2012 at 7:17 AM
    Good351
    Ames, IA
    03 4Runner V8
    Same as Pugga said..
    The guys at Toyota also told me that the trans screen does not need to be replaced..
  15. Dec 21, 2012 at 7:05 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  16. Dec 22, 2012 at 3:36 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    As posted a lot of folks use the Toyota WS fluid. I did not and went with Mobil1 atf.
    I did some research prior to deciding and decided in my opinion the WS is not that special and other fluids with better specs for less money exist.
    Someone posted Amsoil, also I believe Valvoline but it may be another is also Toyata WS rated. Redline has fluid also. Mobil is not WS rated.
    I also drained and filled the rear diff with M1, plus grease my front wheel bearings with M1 grease, also flushed the oem power steering fluid and used M1, coolant I got rid of the stinky Toyota Pink and went with Peak Global (that got rid of the constant coolant smell on shutdown).
    Spark plugs I replaced and installed Denso Irridium fine wires or something like that.
    PK
  17. Oct 8, 2014 at 10:08 AM
    johng34
    johng34 Member
    NH
    2006-4x4 5sp 6.1ft bed
    Hey, PMK, I see that you went with Mobil1. I'm an avid Mobil1 fan. 345k on my Honda civic before I blew a head gasket, day 1 with Mobil 1. 10k between oil changes and at 345k lost about 1/3 qt between changes.
    Why did you decide to go Mobil1 in the AT, knowing it's not WS rated. I called Mobil, they confirmed that answer.
    How's it working for you?
    Thanks,
    Johng34, new member 10/8/14. Just picked up used 2006 taco 110k mi on it. Changed all diff and xfer fluids, going to do tranny soon.
    I recommend dropping the pan, to change the filter which some seem to think doesn't need it, but then you can CLEAN THE MAGNETS in the botton of the pan. IMHO
  18. Oct 8, 2014 at 4:07 PM
    PMK
    Florida
    10 DCLB TRD Sport
    I have had no issues with the M1 in the transmission. With little effort you can see WS is nothing special.
    Another person here, Geacruncher, made similar comments. I believe he is a transmission repair tech or similar. He made his comments well after I was using M1.
    With your truck at 110k, you may be better off keeping the same fluid.
    PK
  19. Oct 8, 2014 at 4:18 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    I recently did the trans flush with 12 quarts on Red Line D6 and installed the Denso Irrduium spark plugs, runs and shift so smooth....
  20. Oct 8, 2014 at 4:41 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Good to hear experiences with mobil1 ATF. I always ran mobil1 but this will be my first time with M1 ATF
