60K service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaEd15, May 16, 2019.
  1. May 17, 2019 at 1:45 PM
    #41
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    :laugh:
    If I recall the price breakdown - it was just over $100 for plugs (parts & labor). The rest was oil filter ($6) and labor for the other stuff.
    TacomaEd15[OP] likes this.
  2. Nov 18, 2019 at 4:19 PM
    #42
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Which dealer do you go to? My 2017 (do realize this is a 2nd gen thread) came from Lee in Topsham and I live near Augusta.
    Last Tacoma was a '99 PreRunner so no front TC or dif so a bit of sticker shock.
  3. Nov 18, 2019 at 6:00 PM
    #43
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    You didn’t follow through and confirm what services were to be provided... it’s a pretty common issue.
    At 60k you should be looking at: 1. A second spark plug change, 2. Your second diff oil change, 3. An ATF swap, 4. When was the last time your brake fluid was swapped? This will set you up nicely for 90k and then 100k when you can do belt, P/S fluid, and coolant.
    It’s nice to space out the bigger items.
    Or, if you aren’t going to keep the vehicle past 150k don’t bother doing any of it because you’ll just throw it away and get something else. It can be someone else’s problem at that point.
  4. Nov 18, 2019 at 7:41 PM
    #44
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m very proactive on my maintenance so every 30k my truck gets:
    Fresh plugs
    Fresh fluids in both boxes, transfer case & manual transmission. All RedLine products so that carries a hefty price tag.
    I too run Mobil1 with and OCI of 5-7.5k and throw in new air filters every 6 months or so.
    The only time I step into the dealer is to haggle over the price of gaskets and oil filters.
  5. Nov 19, 2019 at 6:08 AM
    #45
    Sig45
    Mark
    Maine
    Berlin City in Portland.
