6112/5160 setup with no lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZahyMatar, Nov 12, 2019.
  1. Nov 13, 2019 at 1:06 AM
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    overload out I assume helps a lot. I haven’t had much say with two 450cc snow bikes in the back. Or my RTT set up and loaded down with camping gear. If I need I’ll add air bags down the road. But for now the ride is better on road and on the logging roads i travel on.
    medicfung[QUOTED] likes this.
  2. Nov 13, 2019 at 6:34 AM
    Undertow
    Undertow Well-Known Member
    CT
    2020 Cement DC OR 6MT
    Stock
    Yeah they are about level with the 1" lift in front. Honestly, you can't even tell 1" or .5" rake from no rake visually (I was worried about this too when going to the 6112's @ 2"). It also is wildly different visually depending how you park, incline/decline, etc. But if you just want a 1" in front, look at the Bilstein 5100 adjustables - I *believe* there is a .85" setting in front. Otherwise, the TRD pro suspension gets you where you want to be with a better ride.
