6112 question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZR526, Jun 29, 2022.
  1. Jul 2, 2022 at 10:00 AM
    circlecitymedic
    circlecitymedic Well-Known Member
    Finding a consistent spot to measure was definitely half the battle lol
    ZR526[QUOTED][OP] likes this.
  2. Jul 2, 2022 at 11:27 AM
    ZR526
    ZR526 [OP] Member
    2020 4dr TRD SB
    Body armor front bumper , smitty 9k winch, victory roof rack
    Just what the post after yours said . Support frame with jack stand , mark cams for lower control arm with sharpie and loosen (don’t remove ) , support lower control arm with floor jack and disconnect two bolts under knuckle . Remove top nut from strut and bungee the coil pulling vertically with the upper control arm . Lower jack until you have decompressed enough. The bungee only holds the spring up so you can access the clips. Move clip to desired location , while raising jack guide top of strut through top of the tower and rebolt. 10 min a side . I did this pre alignment so I wasn’t extremely worried about camber changes but the marks made me Put it back where it was .
    GoldenBrew[QUOTED] likes this.
