(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Nov 29, 2012 at 3:08 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    amen Rev. :D
  2. Nov 29, 2012 at 3:13 PM
    nubbs
    nubbs Only from the waist down.
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    3.5" CST Spindle, 5100 Series Bilstien Shocks, 1 1/4" Spidertrax Wheel Spacers, 295/75/16 BFG AT's, EBC Slotted and Dimpled Rotors, EBC Green Stuff Pads, K&N Drop-in, Pioneer Avic-Z110BT GPS Head Unit w/ E-Brake Mod, Ipod Integration, Integrated Pioneer XM Radio Receiver, 6 1/2" Infinity Kappa Separates, 6 1/2" Infinity Kappa Coaxles, Custom Speaker Adapters, PAC Stealth Backup Camera (Because anyone in a double cab knows you can't see the tailgate.)
    Did they claim it would sit higher?
  3. Nov 29, 2012 at 3:58 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    The springs give a 1.6 inch lift alone so yes. I notice a difference but not as big as I thought.
  4. Nov 29, 2012 at 4:26 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    1.6 inch lift? Or dimensionally they are 1.6" longer. If they only happen to be 1.6" longer then that is the maximum they could potentially lift you. But the rate of the spring would also factor in when you put the weight of the truck on them, so dependent upon the rate and the overall length they could also ultimately provide little to no lift. Don't forget that they are brand new springs and they will likely settle in some too.
  5. Nov 29, 2012 at 4:30 PM
    jonny
    jonny Betty White Edition Heep ZJ
    Nubbz talkin out his ass again?
    Hahahhaha
  6. Nov 29, 2012 at 4:31 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Come join me behind the alter little boy..... but leave the cat.;)
  7. Nov 29, 2012 at 4:36 PM
    JaimeSR5
    JaimeSR5 Well-Known Member
    Jaime
    Fontana
    03 PreRunner-4Banger
    K&N filter,-JDM tailights, NGK Spark Plugs, 6k H.I.D head light kit, fog light kit
    idk about L.E.D's, I had them on these fog lights before my accident weren't as bright as I thought they would be.
    but I want to run my bottom corners as a fog light instead of DRL, if the output of the 3ks will burn the corners ill just get the fog light kit and remove those if I can.
  8. Nov 29, 2012 at 4:45 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Are you looking for performance out of the fogs or just the look. If you want a true performing fog lamp, I would think that it's not the size, but how you use it. Typically fog lights are lower wattage than head lights, the idea being that you place the light low so that it doesn't reflect back at you.
  9. Nov 29, 2012 at 4:54 PM
    JaimeSR5
    Jaime
    Fontana
    performance really but i dont want the fogs to take up to much room either, im looking at different fog light kits at the moment.
  10. Nov 29, 2012 at 5:03 PM
    andrew8404
    ANDREW
    Albuquerque, NM
    This ha ha
  11. Nov 29, 2012 at 5:05 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    just went outside and saw my headlights are fogging up...AGAIN! stupid rain :frusty:
  12. Nov 29, 2012 at 5:10 PM
    JaimeSR5
    Jaime
    Fontana
    :eek: hahahahaaaa thats got to suck new sealent for your headlights bro you may have a crack somewhere..
  13. Nov 29, 2012 at 5:12 PM
    Greenbergler
    Corey
    Orange County, CA
    depending on the price i may be interested
  14. Nov 29, 2012 at 5:13 PM
    Greenbergler
    Corey
    Orange County, CA
    anyone got any suggestions for the best sealant? ive fixed one of them before but now it looks like i gotta fix them both now
  15. Nov 29, 2012 at 5:27 PM
    JaimeSR5
    Jaime
    Fontana
    hmmmm on with more research :smash:
  16. Nov 29, 2012 at 6:46 PM
    JaimeSR5
    Jaime
    Fontana
    might do a krylic paint over the corner lights and switch out to the brightest L.E.D. bulb instead, thanks for the Idear :D
  17. Nov 29, 2012 at 6:48 PM
    JaimeSR5
    Jaime
    Fontana
    *krylon* wooopz where is my ABC spell check
  18. Nov 29, 2012 at 7:10 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Why paint? Just get the LEDs in the color you want. No sure how functional they will be as fog lights in those housings, but good luck and let me know how it turns out.
  19. Nov 29, 2012 at 7:32 PM
    JaimeSR5
    Jaime
    Fontana
    instead of having that chrome effect i can just do the krylon stain glass yellow, its more for the rain really lol my headlights are all out of whack IDK if there actually set to where there supposed to be adjusted, i cant see to well in the rain, main purpose why I want to do them brighter, hopefully it works.
  20. Nov 29, 2012 at 8:08 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
