(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Dec 27, 2012 at 3:42 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    ^ how is the ride now ?? Did the springs settle anymore.
    For just the front or all 4 corners?
  2. Dec 27, 2012 at 3:44 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Yeah what time? I'll come by and install my CB too that way all I have to do is just screw my antenna on and tune it.
  3. Dec 27, 2012 at 3:46 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Rides a bit better now. Just wanted to have the springs for when I get spindles. Then i will have little to no preload. Not a huge difference between the 600lbs springs from 700lbs
  4. Dec 27, 2012 at 3:47 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    Not to shabby for $320
  5. Dec 27, 2012 at 3:47 PM
    ProForce
    Anthony
    Alaska
    its not always as nice as everyone thinks...
    Been out of work since February and won't go back till this coming February. Everyone thinks that getting paid to sit on your ass at home is awesome... let me tell you, it sucks! I'm bored all the dam time and just getting more fat :mad:
  6. Dec 27, 2012 at 3:49 PM
    ProForce
    Anthony
    Alaska
  7. Dec 27, 2012 at 3:58 PM
    Manwithoutaplan
    ID
    I get off of work around 430 and i am close to to Hiatt house so i was going to head over right way.
  8. Dec 27, 2012 at 3:59 PM
    Manwithoutaplan
    ID
    Coolio :thumbsup: Not very hard to install those springs either was surprised.
  9. Dec 27, 2012 at 4:01 PM
    Manwithoutaplan
    ID
    I was talking about Jonny being off. I know how you feel about being bored I was unemployed for 1 1/2.
  10. Dec 27, 2012 at 4:59 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i didnt ><
    i was at my GF house... again.. LOL
  11. Dec 27, 2012 at 5:15 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    That's pretty good I would just take the truck to them and they'll do it right the first time and it be worth it in the end. How much would you save if you just to the clam shell and the third member to them
  12. Dec 27, 2012 at 6:00 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    http://www.arrl.org/exam_sessions/search
    Any thoughts on a weekend offroad trip? Hoping for something different than desert terrain.
  13. Dec 27, 2012 at 11:22 PM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    Shane when are You going.to.be home.
    Btw ryan if be careful.with the magnetic attenna because it will make a sun spot type mark whereever you pit it.
  14. Dec 28, 2012 at 12:14 AM
    ProForce
    Anthony
    Alaska
    +1
    Magnet mount antennas are really only designed for temporary use and not recommended for permanent use. If you decide to make that your primary antenna anyways, make sure to occasionally move it around slightly to uncover the spot it was on. Also, every time you wash or move it, be sure to wipe down the area under the antenna. Not only will it create a spot on the paint as well as scratches, but any dirt and moisture trapped under the magnet can cause deterioration and rusting of the paint and roof. Just a heads up.
    Same to you Hiatt.
    Oh and I'll see both you guys tomorrow. Hit me up when your going to Hiatts house Ryan and I'll meet you guys there. Don't forget your SWR if you can bring it. I'll be installing my CB (no antenna yet) and uninstalling my rear light bar for replacement. Let me know if you guys need me to bring any tools or supplies.
  15. Dec 28, 2012 at 5:21 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    only best way to mount an antenna is to drill into the roof and mount a NMO style connector. ground plane and reflectivity is everything. also running a 5/8 wave antenna will give the best signal and gain as opposed to running a mag mount which is a 1/4 wave antenna . something to keep in mind tho is the 5/8 wave antenna is longer then the 1/4 wave. i will switch between the both depending on terrian.. but obviously most wont want to drill into the roof..
    dont worry, its only the tape that looks rough, the hole came out clean
    you can see my "sun spot" from my mag mount cb antenna.. ive had that mag mount since 2003 and still working great even tho i never use the cb anymore
  16. Dec 28, 2012 at 8:55 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    So.... meet and run this sun? holy jim (never been)? breakfast? what yall say?
  17. Dec 28, 2012 at 11:20 AM
    Manwithoutaplan
    ID
    My swr meter is always in my truck. I was also under if i could stick some tape under the mount ?
  18. Dec 28, 2012 at 11:29 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    Gotta break in the new tires :D
    I have never been to holy jim, Where is it at ?
  19. Dec 28, 2012 at 11:39 AM
    Manwithoutaplan
    ID
    You are not Bamf enough to go to Holy JIm :p
  20. Dec 28, 2012 at 1:24 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    I have a B.A.M.F sticker, so that should give me supercharging 4wd powers. Where is Holy Jim? Near Trabuco Canyon?
