(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Dec 31, 2012 at 8:00 AM
    Tacofire
    Tacofire Well-Known Member
    donovan
    West Covina
    Black 2012 Tacoma 4 door 4x4
    black mesh grill insert painted black stock wheels tint 3 inch lift AAL smoked rear lights volant cold air filter headlight and fog HID with LED interior lighting and a KCCO sticker
    Happy new year everyone!!!!!
  2. Dec 31, 2012 at 8:02 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    Does that make for better tuning? Maybe seeing those 30+ hp for just an intake?
  3. Dec 31, 2012 at 2:23 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
  4. Dec 31, 2012 at 2:57 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Anyone had an alignment done and been told that they need to use a "true align" system which costs more due to the aftermarket wheels/tires? Shop told me that my rim won't accept a standard alignment rack setup but luckily my tires have enough lip so they can still do it the normal way, but said if I ever get different tires with a smaller lip that its and extra $50 every time to use a "true-align" setup.
    BS :notsure:
  5. Dec 31, 2012 at 4:09 PM
    ProForce
    Anthony
    Alaska
    Might have a bad ball joint :( or a strut mount bushing. Trucks up on the rack now getting checked out and aligned.
  6. Dec 31, 2012 at 5:32 PM
    ProForce
    Anthony
    Alaska
    Truck is fixed :taco:
    Got the lifetime alignment at Firestone and this is the first time my truck actually drives straight after only 1 try on the rack. Took the dealer 3 tries and my steering wheel was still crooked. I live within walking distance of the Diamond Bar location but opted to go to Chino Hills due to better reviews. Was a good decision. They also reset the sensors for free so my light is off and no more issues with ABS, Trac, or LSD. Could have been much worse I suppose. Total cost was $200 flat, but had some other routine maintenance done as well.
    But I do have a loud clunk/popping sound coming from the front end. Only happens after switching to reverse and applying the brakes for the first time, or switching to drive and applying the brakes the first time. Everyone said this is the brake pads slipping, but I confirmed that this was not the case. The noise is possibly a ball joint popping or a bad strut mount bushing. I need someone else to help me figure it out. Or maybe a GoPro. Anyways... all good now :D
  7. Dec 31, 2012 at 5:34 PM
    nubbs
    nubbs Only from the waist down.
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    3.5" CST Spindle, 5100 Series Bilstien Shocks, 1 1/4" Spidertrax Wheel Spacers, 295/75/16 BFG AT's, EBC Slotted and Dimpled Rotors, EBC Green Stuff Pads, K&N Drop-in, Pioneer Avic-Z110BT GPS Head Unit w/ E-Brake Mod, Ipod Integration, Integrated Pioneer XM Radio Receiver, 6 1/2" Infinity Kappa Separates, 6 1/2" Infinity Kappa Coaxles, Custom Speaker Adapters, PAC Stealth Backup Camera (Because anyone in a double cab knows you can't see the tailgate.)
  8. Dec 31, 2012 at 5:40 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    It's most likely ball joints. Rodger had the same problem
  9. Dec 31, 2012 at 5:42 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    What kit is that??
  10. Dec 31, 2012 at 5:45 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Jack up the front end of the truck so that there is about a 1 1/2" gap between your tire and the ground. Then grab a long pry bar or something similar and pry up on your tire, this will show you if you have a bad ball joint or wheel bearing.
  11. Dec 31, 2012 at 5:54 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Glad you got that fixed.
  12. Dec 31, 2012 at 5:57 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Its a 6 channel, 120 watt kit. Came with 6 bulbs, wires, transformer and a switch box. I dissected the switch box, took the momentary switch and put it in one of the blanks and then used a Toyota rocker switch for the power.
  13. Dec 31, 2012 at 6:40 PM
    ProForce
    Anthony
    Alaska
    When the truck was on the lift today I had the guy pull on the tire from top/bottom and side/side. There wasn't any major noticeable play in the wheel. He said wheel bearing were fine, but its possible that the ball joint is gone.
    Just weird rhat it only happens during the first time I apply the brakes after switching from R-D or vise versa. Never does it any other time. I know it seems as though its the pads sliding around but its WAY too loud for that. Sounds like a metal "clunk-clunk" or pop. I need someone more experienced with this to listen to it for me.
    If I got new UCA's, does that automatically replace my ball joints then? Like the LR ones? Noob questions :sorry:
  14. Dec 31, 2012 at 6:42 PM
    ProForce
    Anthony
    Alaska
    X2 what brand? Link?
  15. Dec 31, 2012 at 6:44 PM
    ProForce
    Anthony
    Alaska
    What's everyone doing tonight?
  16. Dec 31, 2012 at 7:24 PM
    jobrien
    Josh
    Ontario California
    stayin home, drinking a beer, watching the walking dead and eating home made burritos with carne asada rice and beans. and maybe bringing in the new year with a BANG!!! if ya know what i mean:eek::D
  17. Dec 31, 2012 at 7:43 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
  18. Dec 31, 2012 at 7:46 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    Big night out.... Starbucks, Target and grocery store. :(
  19. Dec 31, 2012 at 7:49 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ya thats what my drivers side ball joint did...it would only make noise when going from P-D and turning the wheel when stopped
  20. Dec 31, 2012 at 8:15 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Love the Firestone lifetime alignment!
