(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Mar 11, 2013 at 3:53 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Are we still on for that "idea" I had the other week?
    Mod powerz for errryboddayy
  2. Mar 11, 2013 at 3:54 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Details or GTFO! Some of the questions answered in your LED swap thread...lol. I answer 'em in a few seconds flat.
    Wtf happened sat?
  3. Mar 11, 2013 at 3:55 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    who locked you down ????
  4. Mar 11, 2013 at 3:55 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Was getting great towards the end when everyone started to question the holes in your story lmao hahahahaha
  5. Mar 11, 2013 at 3:57 PM
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    TL:DR. I'm gonna have ProForce summarize it for me.
  6. Mar 11, 2013 at 3:58 PM
    The Traveler
    SoCal
    Tiger...but it was needed. All the cop haters started emerging from the depths.
    LMAO my story is airtight because it's the TRUTH!!! You can ask Ryan and Brad, nothing I said there was false. Based on pure observance of the incident and what the cops told us.
  7. Mar 11, 2013 at 3:59 PM
    The Traveler
    SoCal
    Good luck. It'll probably be even longer :rolleyes:
  8. Mar 11, 2013 at 4:02 PM
    Manwithoutaplan
    ID
    damn i missed it :(.
  9. Mar 11, 2013 at 4:11 PM
    Blown383
    Blown383 Well-Known Member
    I bought a bunch of these generic Hanma DOUBLE row LED light bars last year and have a few left over from the group buy that are display models.
    The 40 inch which will fit the Baja Racks & the Gobi racks and a single 20 inch which works great for front/rear bumper mounting.
    These bars are BRIGHT! If you look directly into them I guarantee that you'll go BLIND. Also they come with a 1 year warranty!
    I don't have tons of posts here but I have well over 400 posts on the FJ Cruiser Forums and the same post can be found here:
    http://www.fjcruiserforums.com/forums/want-sell-fj-related-items/162247-40-inch-20-inch-led-light-bars-sale-socal.html
    and here:
    http://www.tacomaworld.com/forum/bu...0-inch-20-inch-led-light-bars-sale-socal.html
    I'm located in Southern California so no waiting 3-4 weeks for the bars to arrive.
    $500 for the 40 inch. I have 2 of these!
    Specs on the 40 inch bar are:
    . 240Watts
    . Operating Voltage: 10-30V DC
    . Waterproof rate: IP 67
    . 80 individual 3w high intensity Epistar LEDs
    . 17,600 lumens!
    . Current draw 16A @ 12V,8A @ 24V
    . Color: Black
    . Color Temperature: 6000K
    . Material: Die-cast aluminum housing
    . Lens material: Toughened glass
    . Mounting Bracket: Aluminum bracket
    . Combo spot/flood beam pattern
    . 30,000 hours+ life expectancy
    . Dimensions: Housing = 41.5". Mounting feet = 44".
    $300 for the 20 inch bar.
    Specs on the 20 incher
    . Power: 120 Watts
    . 40 individual 3w high intensity Epistar LEDs
    . 8,800 lumens!!!
    . Current draw 8A @ 12V,16A@24V
    . Color: Black
    . Lens material:Toughened glass
    . Dimensions: Housing = 21.5 inch overall. Mounting legs = 24"
    Here are the bars mounted on my FJ.
    I'm located in Southern California.
    -B
  10. Mar 11, 2013 at 4:19 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    :rant:
    :brianr:
  11. Mar 11, 2013 at 4:19 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    fuck the bs...i want that 40 in. light bar just for shits and giggles...lol
  12. Mar 11, 2013 at 4:21 PM
    The Traveler
    SoCal
    Jasper's are cheaper at $450...almost 18,000 lumens :eek:
  13. Mar 11, 2013 at 5:25 PM
    ProForce
    Anthony
    Alaska
    :eek::eek::eek::eek:
    Normal?? No?? This is fresh. I've had normal light leakage around the main large outer main seal before (as seen in 2nd pic) but this leakage around the fill plug and rear outer seal is brand new. Ideas? What would cause a sudden leak at 2 different gaskets?
  14. Mar 11, 2013 at 5:41 PM
    MonkeyProof
    SoCal- SGV
    Seepage around the fill plug is normal..nothing worry to worry about, but if you want total piece of mind then replace the washer. Its 2 bucks from the dealership..
    The other leak is common as well..mine did it but a lot worse then yours. Looks like it just started actually. Its the nuts on the studs that holds the 3rd member to your axle housing. Over time torque from the motor down through the drive shaft will work them loose. Easy. fix with a torque wrench and a 12mm socket..retorque the nuts to 18ft.lbs/27nms. Ibwoulx recommend to retorque the diff studs nuts about every 15k miles.
    This is what mine looked like when it was first noticed..was actually dripping..
  15. Mar 11, 2013 at 6:11 PM
    ProForce
    Anthony
    Alaska
    ^^ great info! Thanks!
    Can anyone tell me the best way to fix steering wheel vibes between 52-65mph?? I could search a bazillion threads but I'm sure someone here knows.
    In case this helps, I'm running 5100's up front @ 1.75 on stock uppers and coils and stock length rear billies with tsb pack.
    Think that TSB tranny mount replacement might help? :notsure:
    Its for sure not my tires cuz I had them rebalanced 5 times and also had them check for belt shifts and defects. They tested perfect. Rims are also not bent.
    Vibes are intermittent and vary in intensity.
    Suggestions?
  16. Mar 11, 2013 at 6:16 PM
    The Traveler
    SoCal
    Have them road force balanced. After I did mine (also after countless rebalances), it completely went away. If that doesn't help, make sure the alignment is good too.
    Also, make sure your pressure is correct in all the tires.
  17. Mar 11, 2013 at 6:36 PM
    ProForce
    Anthony
    Alaska
    PSI is an even 40 all around and Alignment is perfect. Can Americas tire company road force balance? I have lifetime mount/balance/rotate there and would rather not pay someone else to do it since I've already paid for it
  18. Mar 11, 2013 at 6:59 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    roadforce is normally extra $$$
  19. Mar 11, 2013 at 7:00 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    yo ryceps...are you dieting + workouts or just workouts and cutting down?
  20. Mar 11, 2013 at 7:19 PM
    Manwithoutaplan
    ID
    Dieting and working out. Yo
