(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Apr 29, 2013 at 11:28 AM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    hey roger how long would take to wire this up on my truck when i get it in ??
  2. Apr 29, 2013 at 11:34 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    From battery to the main terminal not long...it will take long running wires for different components to it lol
    How much is that? I wanted to add something like that to my truck as well
  3. Apr 29, 2013 at 11:35 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    That's the blue sea one isn't it? West Marine carries this in stock usually for like $60.
  4. Apr 29, 2013 at 11:36 AM
    Manwithoutaplan
    ID
  5. Apr 29, 2013 at 11:41 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Where are you mounting it Ryan?
  6. Apr 29, 2013 at 11:44 AM
    Manwithoutaplan
    ID
    not sure :S. So much garbage in one little area. I was thinking on top of the fuse box lid.
  7. Apr 29, 2013 at 11:47 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    That's where I would want to mount mine...
    What I would do is get the same gauge wire as the stock battery's and cut the pos (+), crimp it in with a new terminal adding the new wire for the new fuse box and the ground it to the battery ground
  8. Apr 29, 2013 at 11:49 AM
    Manwithoutaplan
    ID
    Should i get this to ?
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=185
  9. Apr 29, 2013 at 11:50 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    What are you going to run off of it?
  10. Apr 29, 2013 at 11:51 AM
    Manwithoutaplan
    ID
    Nofords suggested it.
  11. Apr 29, 2013 at 11:52 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
  12. Apr 29, 2013 at 11:57 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    I see...8g wire is good to go so (check) - inline fuses too
    Fuse box (check)
    The circuit breaker is a safety precaution to the fuses...but in this case it's all together: a good thing to have.
    Ill be ordering one this weekend once my check arrives.
  13. Apr 29, 2013 at 12:09 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    It's 2 bulbs. I have an extra ac controls one at my house if you want it. Pretty sure it's a good one and not a bad one. I'll check later today. But if its good you can have it if you don't already have one
  14. Apr 29, 2013 at 12:10 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    You need 4g wire for that, not 8.
  15. Apr 29, 2013 at 12:11 PM
    Manwithoutaplan
    ID
    It is ok i can get it from King bolt they have all the nuts and wires :D.
  16. Apr 29, 2013 at 12:17 PM
    ProForce
    Anthony
    Alaska
    Ryan did you install your arb compressor between the fuse box and master cylinder? I forget. If not, this is where I installed one before, came out good right there. Made a small shelf type bracket out of tin. Oh and the circuit breaker really isn't necessary. But don't hook your compressor to the fuse box that should still go straight to battery.
    Before:
    After:
  17. Apr 29, 2013 at 12:19 PM
    Manwithoutaplan
    ID
    yea i but between the fuse box and master cylinder.
    Does the Compressor need Direct Power??
  18. Apr 29, 2013 at 12:22 PM
    ProForce
    Anthony
    Alaska
    It should. Just like a winch. Those 2 things should not go to a fuse box
  19. Apr 29, 2013 at 12:24 PM
    Manwithoutaplan
    ID
    okie dokie. Good thing to know.
  20. Apr 29, 2013 at 12:49 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    ^^ You putting in double batteries, too?
