(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Dec 23, 2013 at 2:49 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
  2. Dec 23, 2013 at 3:06 PM
    Tacofire
    Tacofire Well-Known Member
    donovan
    West Covina
    Black 2012 Tacoma 4 door 4x4
    black mesh grill insert painted black stock wheels tint 3 inch lift AAL smoked rear lights volant cold air filter headlight and fog HID with LED interior lighting and a KCCO sticker
    Named mine after my first horse (his name was cutter)
  3. Dec 23, 2013 at 3:11 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    • [​IMG]
    i can see why you called it the cutter
  4. Dec 23, 2013 at 4:04 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    Anyone wanna buy a stock shifter (less than 200 miles on it) looks mint
    Also some icon sway bar spacers...
    Make me an offer
  5. Dec 23, 2013 at 4:14 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
  6. Dec 23, 2013 at 4:16 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    $5.25
  7. Dec 23, 2013 at 4:18 PM
    Jerez
    Rod
    Estock
    you haz a 6 speed...unless youre going to use it for something else that shouldnt be spoken about :anonymous:
  8. Dec 23, 2013 at 4:32 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    anyone want to help with my LED bar wiring? everything is mounted just need a little help with wiring.
    It works except i cant get it to work with my switch. Should have looked at my old setup. I just ripped the wires out.
  9. Dec 23, 2013 at 5:04 PM
    Menj309
    Menj309 Well-Known Member
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    Your not alone I named my Lexi
  10. Dec 23, 2013 at 5:28 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Is it a 3 prong switch?
  11. Dec 23, 2013 at 5:32 PM
    adriancast
    Adrian
    Ontario, Ca
    Just got it. Thanks tho. Appreciate the response.
  12. Dec 23, 2013 at 7:04 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    where do you guys put switches if you run out of factory blanks? and whats the yellow wire mod?
  13. Dec 23, 2013 at 7:41 PM
    Jerez
    Rod
    Estock
  14. Dec 23, 2013 at 7:45 PM
    Greenbergler
    Corey
    Orange County, CA
  15. Dec 23, 2013 at 11:26 PM
    adriancast
    Adrian
    Ontario, Ca
    Just installed and hooked up my new 30 inch double row LED bar (14,400 lumens) from OKLEDLIGHTBARS. This thing is built with quality. Super bright. Here are some pics. Even though it is brighter in person/driving.
    Headlights Only
    Headlights/Fogs Only
    Headlights/Fogs/LED Bar
  16. Dec 23, 2013 at 11:44 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
  17. Dec 23, 2013 at 11:50 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    btw are you stationed at camp pendleton?
  18. Dec 23, 2013 at 11:53 PM
    adriancast
    Adrian
    Ontario, Ca
    :cool:
    Miramar
  19. Dec 23, 2013 at 11:55 PM
    AsianAnts
    AnT
    kill
  20. Dec 23, 2013 at 11:56 PM
    adriancast
    Adrian
    Ontario, Ca
    :cheers:
