(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Sep 21, 2011 at 5:37 PM
    #4061
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ya as long as its from 11-5 im good :D
  2. Sep 21, 2011 at 5:39 PM
    #4062
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Well Ryan. Do you mind if we meet at your place at 12?
  3. Sep 21, 2011 at 6:05 PM
    #4063
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    i can do after 1130am if you want.
  4. Sep 21, 2011 at 6:06 PM
    #4064
    Manwithoutaplan
    ID
    that works. I have done both front and back hiatt.
  5. Sep 21, 2011 at 6:08 PM
    #4065
    Hiatt1991
    Hiatt
    Ventura, CA
    Awesome. I think I still have your number. If not ill pm you. Thanks again guys. Except for Christian.... :D
  6. Sep 21, 2011 at 6:09 PM
    #4066
    Manwithoutaplan
    ID
    Hey go to the automotive store and get the toll where you can take the drum brakes off. Also for the drum brakes you are going to get them humoed out, by a local automotive store. Also bring brake cleaner and make sure you have the oil pack it to put on the back of the brakes.
  7. Sep 21, 2011 at 6:13 PM
    #4067
    Manwithoutaplan
    ID
    hey christian do you have that tool to pull the brake drums off ????
  8. Sep 21, 2011 at 6:22 PM
    #4068
    Hiatt1991
    Hiatt
    Ventura, CA
    Oh your not supposed to use a mallet. Ive taken off the drums to clean them. Theres a threading for either an 8mm or 10mm bolt and as you tighten that, it forces the drum strait off. I remember reading that banging on it can f with the weights on the drum.
  9. Sep 21, 2011 at 6:28 PM
    #4069
    Hiatt1991
    Hiatt
    Ventura, CA
    I tried it with a mallet and it didnt work one bit. Then I saw those bolt holes and I had em off in 5 min.
  10. Sep 21, 2011 at 7:16 PM
    #4070
    nubbs
    nubbs Only from the waist down.
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    3.5" CST Spindle, 5100 Series Bilstien Shocks, 1 1/4" Spidertrax Wheel Spacers, 295/75/16 BFG AT's, EBC Slotted and Dimpled Rotors, EBC Green Stuff Pads, K&N Drop-in, Pioneer Avic-Z110BT GPS Head Unit w/ E-Brake Mod, Ipod Integration, Integrated Pioneer XM Radio Receiver, 6 1/2" Infinity Kappa Separates, 6 1/2" Infinity Kappa Coaxles, Custom Speaker Adapters, PAC Stealth Backup Camera (Because anyone in a double cab knows you can't see the tailgate.)
    There's a hanger for the rear brake lines on the frame near the perch. Just pull that bolt and you can use that.
  11. Sep 21, 2011 at 7:18 PM
    #4071
    Jerez
    Rod
    Ontario Ranch
    Estock
    Shit :facepalm: I forgot to order the LEDs for my uncles tacoma....I wanted to work on it this weekend....
  12. Sep 21, 2011 at 7:40 PM
    #4072
    Manwithoutaplan
    ID
    i am guessing you do not need red and blue??
  13. Sep 21, 2011 at 7:44 PM
    #4073
    Jerez
    Rod
    Ontario Ranch
    Estock
    I need red for the radio...not the cluster lol
  14. Sep 21, 2011 at 7:46 PM
    #4074
    Hiatt1991
    Hiatt
    Ventura, CA
    Thanks dude! I was actually about to go buy one. Haha
  15. Sep 21, 2011 at 7:52 PM
    #4075
    Manwithoutaplan
    ID
    what is the tool called??
  16. Sep 21, 2011 at 7:56 PM
    #4076
    Hiatt1991
    Hiatt
    Ventura, CA
    Wich one? The spring puller?
  17. Sep 21, 2011 at 8:01 PM
    #4077
    Manwithoutaplan
    ID
    the one to pull of the brake drum
  18. Sep 21, 2011 at 8:19 PM
    #4078
    Manwithoutaplan
    ID
  19. Sep 22, 2011 at 9:15 AM
    #4079
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    So....isn't ATRAC that greatest thing ever?!?!?!
  20. Sep 22, 2011 at 9:25 AM
    #4080
    jonny
    jonny Betty White Edition Heep ZJ
    :cool:
    .........again..........
