(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Jun 9, 2014 at 4:22 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Anthony, your truck doesn't have a slip yoke unless you added one. You must mean the carrier bearing. Nick can make you one but he prolly didn't know what you were talking about if you said "slip yoke". Only person who makes them is a guy on here named "streettacos". He has a website. Look him up.
  2. Jun 9, 2014 at 4:40 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    And you don't have to worry about a pissed off dad!
  3. Jun 9, 2014 at 4:44 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Sweeeeet! :wave:
    Da da daaaaaaaaaaaaaa!!! At one of your homes, I see. Hard to choose which one? Jeeeez, even Hiatt is coming in........
    Yeah, it is what it is. I knew I was out when they said I should fill out a form. At least I got four episodes of crazy adventure in AK.
    HEY!!! Your face = Shut it....... :p
  4. Jun 9, 2014 at 4:44 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    Double touché
  5. Jun 9, 2014 at 4:44 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Wait! You have a 3 inch lift and it pulled out your driveline to the max limit?
  6. Jun 9, 2014 at 4:45 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
  7. Jun 9, 2014 at 4:54 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    The tranny yoke is some times refered to as a slip yoke too...even the dumb peeps at dealer :facepalm:
  8. Jun 9, 2014 at 4:57 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    :laugh:
  9. Jun 9, 2014 at 4:57 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    What do you guys recommend for cleaning the trd seats?
  10. Jun 9, 2014 at 5:30 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Whatever extends out of the tranny. Its pulled out a full inch and doesnt seem very stable. Ive seen the spacers online that I need. Ive even found a couple threads about it but cant find any links. Nick thought I meant the CB drop but i showed him a picture and he said to try a machine shop. Ill get pictures later for you guys
  11. Jun 9, 2014 at 5:30 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    In a bowl add some vinegar, hot water and dish soap and with a rag clean them.
    Look online there's a bunch of things for the fabric
  12. Jun 9, 2014 at 5:31 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    We know what you mean. Hiatts is like that.
    Mine was but I added that slip yoke for that reason to push the transmission yoke flush
    It's not going to slide out. You'll be fine
  13. Jun 9, 2014 at 5:54 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    just go ahead and sit on it. im sure it'll support you HAHAHAHA
  14. Jun 9, 2014 at 7:48 PM
    Manwithoutaplan
    ID
    Yea buddy :woot: :woot:
    Go Kings Go!!!!!!!!!!!!
  15. Jun 9, 2014 at 8:26 PM
    Greenbergler
    Corey
    Orange County, CA
    :rofl: hahaha! Only you would've seen that. Hahahaha
  16. Jun 9, 2014 at 8:41 PM
    ProForce
    Anthony
    Alaska
    hahaha ok I had that one coming for me. You win lol
    So I found my stupid spacer that I need! :woot: Took long enough and cost me $82 but it will be WELL worth it.
  17. Jun 9, 2014 at 8:48 PM
    ProForce
    Anthony
    Alaska
    In case anyone was curious or is having a similar issue with vibes or take off shudder, this:
    http://www.tacomaworld.com/forum/2n...rive-shaft-vibrations-solved-step-step-8.html
    is the thread that shows the solution. First post on top of page 8 shows pics of what mine looked like exactly. you can see the driveshaft pulled out of the transmission yoke by quite a bit. you can also see the rubber boot on the carrier bearing pulled out alot. Both of those issues can cause your CB to go out very fast and can also damage the seal in the tranny yoke. Scroll down a few posts and it shows the spacer that was added and how it solves all of the problems and puts the shaft back to the correct position. Then add a small CB drop and problems solved. back to stock angles and no vibes.
  18. Jun 9, 2014 at 10:35 PM
    ProForce
    Anthony
    Alaska
    What would cause a steering when wobble ONLY during braking and ONLY during 40-50pmh. I thought only warped rotors caused that but wouldn't it be at any speed during braking?
  19. Jun 9, 2014 at 10:49 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No warp rotors can be at a random speed as well. Or unbalanced tires too
  20. Jun 9, 2014 at 11:38 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    My warped rotors shook my steering wheels at 60-65 my bend wheel shook it at 55-60 hahaha. Fml
