(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Jan 16, 2015 at 8:27 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Hey guys,
    Can anyone recommend a trusted clutch guy? I'd like it done tomorrow if possible. Anyone do it on the side? Thanks fellas.
  2. Jan 16, 2015 at 8:44 AM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    This is wrong place to ask this questions, all these nannies drive auto's.
  3. Jan 16, 2015 at 8:46 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    I don't see you offering up any suggestions... :rolleyes:
  4. Jan 16, 2015 at 9:00 AM
    Manwithoutaplan
    ID
    I have a place but little far for him. :p
  5. Jan 16, 2015 at 9:02 AM
    Manwithoutaplan
    ID
    you should ask HBtaco02 cause he has MT too and he lives in HB.
  6. Jan 16, 2015 at 9:05 AM
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Slow your roll Ryan. I drive manual! But no I dont have anyone to recommend :sorry:
  7. Jan 16, 2015 at 9:09 AM
    Manwithoutaplan
    ID
  8. Jan 16, 2015 at 9:13 AM
    Shauncho
    Shaun
    Parts Unknown...
    none
  9. Jan 16, 2015 at 9:36 AM
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Pretty much! I am out of it guys give me a break.... I missed TW yesterday:pout:
  10. Jan 16, 2015 at 9:53 AM
    Lpheat22
    Lpheat22 Well-Known Member
    Albert
    La Puente, SGV
    09 PreRunner SR5 DCSB Sport
    DDM Tuning 6000k HID Headlights, Pioneer X5500BHS, CSJumper switchbacks, Fox 2.5 w/reservoirs and CDC adjusters, Sick Nick PreRunner Tube Bumper, 17 in SCS Stealth 6's Matte Gunmetal, Toyo ATII 285/70/17
    You have 3000 posts already?! Holy fuck guy go outside
  11. Jan 16, 2015 at 9:54 AM
    Manwithoutaplan
    ID
    don't be mad.
  12. Jan 16, 2015 at 10:04 AM
    Manwithoutaplan
    ID
    not at all just laughing at the video.
  13. Jan 16, 2015 at 10:07 AM
    Lpheat22
    Albert
    La Puente, SGV
    I'm here for the shits and giggles.
  14. Jan 16, 2015 at 10:10 AM
    Lpheat22
    Albert
    La Puente, SGV
  15. Jan 16, 2015 at 10:11 AM
    Manwithoutaplan
    ID
  16. Jan 16, 2015 at 10:17 AM
    Manwithoutaplan
    ID
  17. Jan 16, 2015 at 10:20 AM
    Manwithoutaplan
    ID
    I need to get one for moab this year.
  18. Jan 16, 2015 at 10:25 AM
    Manwithoutaplan
    ID
    I am thinking the same thing.
    But what happens if you only fill your tires up at cost co with pure Nitrogen? Because i only fill my tires up there.
  19. Jan 16, 2015 at 10:29 AM
    Shauncho
    Shaun
    Parts Unknown...
    none
    approx how many tires can a 15lb tank fill?
  20. Jan 16, 2015 at 10:30 AM
    Manwithoutaplan
    ID
    search nooob good lord :facepalm:
    http://www.instantairsupply.com/hom...system-with-quick-fist-mounting-solution.html
    5lb On Board Air System. This system will allow you to quickly and easily air your tires back up to street pressure after off-road use. The 10lb system is the perfect size for most applications. This system will allow you to fill a 35" tire from 8 to 22psi 30 times. If you have smaller tires or don't air down that low you can expect more tire fills. This system can also run air tools and handle all other inflation needs.
    With this system you will save time at the end of a long wheeling day. While your friends struggle with inferior 12v inflators you will very quickly be able to air your tires back up to street pressure. On average it will take less than 1 minute to fill each tire! This system uses a standard NON coiled air hose and a high quality, commercial grade euro style air chuck to allow a secure connection to the valve stem. This allows you to attach the air line without having to constantly hold the air chuck, and without pulling on your valve stem. DO NOT LEAVE AN INFLATING TIRE UNATTENDED! Over time you will learn approximately how long it takes to fill a tire with your particular set up. Be sure to use an accurate air pressure gauge to monitor your progress. You are responsible to safely inflate your tires, and must understand that over inflating a tire is very dangerous. IAS can not be held liable for improper inflation techniques or user incompetence while operating this system.
    Your Co2 OBA system can also be used for many other inflation needs, some examples: Air tools, blow guns, inflating mattresses, flotation devices, bicycle tires, balls. You will find that you will use this system at the camp site for many other things beyond just filling tires. You may even find yourself using it around the house as a portable air source.
    Your IAS 15lb Aluminum Co2 cylinder is made in USA and will always have a very fresh test date. Cylinders need re-tested every 5 years and this can usually be done at your local welding supply or beverage supply. You can fill your Co2 cylinder at most beverage supply outfits, welding shops or bulk industrial supply houses. The easiest place to have one filled is a beverage supply outfit. Compressed Co2 is most commonly used in every fountain soda machine on the planet, so finding a local beverage supply outfit should be very easy. Cost on average for a 10lb fill should be around $15. If you need help finding a place to fill your Co2 cylinder contact IAS and we will help!
    Note: During use the cylinder must be in a verticle orientation. You can store the cylinder horizontally.
    Included in kit:
    15lb Aluminum Co2 cylinder w/handle (dimensions: 7" diameter and 27" tall)
    150psi fixed rate Co2 regulator
    25' braided polyurethane air hose
    2qty. reusable 1/4" hose ends with strain relief (this allows you to easily splice a damaged hose or build a new hose)
    1 Male 6 ball premium brass industrial quick release air coupler
    1 Female 6 ball premium brass industrial quick release air coupler
    1 Male steel air plug
    1 Female steel air plug
    Premium quality brass euro style inflation chuck
    2 Quick fist rubber mounts
    IAS vinyl decal
