(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Mar 14, 2012 at 12:28 PM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Figured, but I had to ask.
  2. Mar 14, 2012 at 12:30 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    ok fair trade for waffles :D
  3. Mar 14, 2012 at 12:31 PM
    Manwithoutaplan
    ID
    :rofl:
  4. Mar 14, 2012 at 12:43 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    does anyone know anything about micro controllers and C programming???
    #include <system.h> //pic definition files required by boostc
    #pragma CLOCK_FREQ 48000000 //Set clock frequency
    void main()
    trisa = 0; //set all porta to output
    porta = 0; //set all porta pins to logic (0V)
    while( 1 ) // A endless while loop
    // Turn on and Turn off LEDs and delay 200 millisecond,
    // keep going and start over again with a endless while loop
    porta = 0b00000001; // Set Port a to 0b00000001;
    delay_ms(200); // Delay 200 milliseconds
    porta = 0b00000010;
    delay_ms(200);
    porta = 0b00000100;
    delay_ms(200);
    porta = 0b00001000;
    delay_ms(200);
    porta = 0b00000100;
    delay_ms(200);
    porta = 0b00100010;
    delay_ms(200);
    porta = 0b00000001;
    delay_ms(200);
    i am eeeeffffaawwwking lost :confused: :censored:
  5. Mar 14, 2012 at 12:54 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    probably stating the obvious but looks like code to program some kind of LED indicator light to flash at a specified interval. WTF are you using this on ?
  6. Mar 14, 2012 at 1:02 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    :taco: +plus 1 for you my friend lol
    i have this board wired up to this computer right now....
    "Modify the program so that the pattern lights two LED’s at a time."
    i had it down last week but for some reason its not working...
  7. Mar 14, 2012 at 1:33 PM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    Where you getting them to blink?
    And or say some thing or just getting them to flash.?
    0b00000010-0b00000100 Are you sure that tho's are correct?
    The delay is correct. From what i see.. porta = 0b00000001; And going down are not.
    try a void loop()
  8. Mar 14, 2012 at 1:36 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    i removed porta = 0b00000001; because that was the last delay it had...
    now i need to make the lights light up 2 leds at a time...
    for some reason i cant understand this shit lol
  9. Mar 14, 2012 at 1:38 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    hard to explain this thru a computer lol..
  10. Mar 14, 2012 at 1:44 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    /* Blink Multiple LEDs without Delay
    * Turns on and off several light emitting diode(LED) connected to a digital
    * pin, without using the delay() function. This means that other code
    * can run at the same time without being interrupted by the LED code.
    int led1 = 13; // LED connected to digital pin 13
    int led2 = 12;
    int value1 = LOW; // previous value of the LED
    int value2 = LOW; // previous value of the LED
    long time1 = millis();
    long time2 = millis();
    long interval1 = 1000; // interval at which to blink (milliseconds)
    long interval2 = 500;
    void setup()
    pinMode(led1, OUTPUT); // sets the digital pin as output
    pinMode(led2, OUTPUT);
    void loop()
    unsigned long m = millis();
    if (m - time1 > interval1){
    time1 = m;
    if (value1 == LOW)
    value1 = HIGH;
    else
    value1 = LOW;
    digitalWrite(led1, value1);
    if (m - time2 > interval2){
    time2 = m;
    if (value2 == LOW)
    value2 = HIGH;
    else
    value2 = LOW;
    digitalWrite(led2, value2);
    ""Your going to have to set each pin in order to do that""
  11. Mar 14, 2012 at 1:45 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Try a try a-----> void loop()
    That way it will void some of the led's and still run.. This will take time to get it correct.
  12. Mar 14, 2012 at 2:45 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  13. Mar 14, 2012 at 2:57 PM
    ruler
    lmao a Suburu Brat ? that thing is one ugly sucker !
  14. Mar 14, 2012 at 2:58 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    all wheel drive, tune it up, you yerself a nice lil' rally truck
  15. Mar 14, 2012 at 4:40 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    ok i have a question for all you guys running hid headlights, i have hids on my truck and one of them seems dimmer then the other and more of a purple then blue like the other headlight it just started doing it yesterday is it cause the bulb is going out or what ?
  16. Mar 14, 2012 at 4:42 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    im 80% sure its the bulb....does it flicker or anything??
    one way to test it is swap the ballast between both headlights...
  17. Mar 14, 2012 at 5:41 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Need new ones... its the bulb.
  18. Mar 14, 2012 at 7:17 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    If you flop your junk or even roll it..you'll need to pull the plugs out lol...I have it down to less then 15 minutes for all six plugs on the crawler :D
  19. Mar 14, 2012 at 9:39 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Alright then where is a good place to get hid bulbs ?
  20. Mar 14, 2012 at 9:59 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    anyone like the beach?
