(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Jun 27, 2012 at 9:40 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    David k doesn't approve
  2. Jun 27, 2012 at 10:13 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  3. Jun 27, 2012 at 2:04 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    Btw Monkeyproof thx for helping me yesterday in correcting my problem :thumbsup:
  4. Jun 27, 2012 at 2:05 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    dumb questions alert!
    In the future, if i purchase an ARB air locker (because i have a TRD sport model and not the offroad model)...can i somehow use that has an on board air compressor to inflate my tires? or will i need a system independant from the ARB product.?
    thanks heh
  5. Jun 27, 2012 at 2:09 PM
    Manwithoutaplan
    ID
    you can use arb to inflate your tires but i guess it is really slow, might as well have seperate compressor. YOu could also get a bigger compressor.. http://www.quadratec.com/products/16104_900X_PG.htm
    Or you could get some comparable.
  6. Jun 27, 2012 at 2:20 PM
    AsianAnts
    AnT
    So that product that you have provided is just for the compressor, correct?... i would also have to get the locker kit to complete my needs for a locker and tire inflator?
    OR
    that product alone that you have provided below will do the trick for my needs?
  7. Jun 27, 2012 at 2:25 PM
    Manwithoutaplan
    ID
  8. Jun 27, 2012 at 2:27 PM
    Manwithoutaplan
    ID
    you might want to look at Eastcoastgearsupply.com where they do 3rd members which it might be cheaper to do.
  9. Jun 27, 2012 at 2:29 PM
    jonny
    jonny Betty White Edition Heep ZJ
    and possibly spin out on icy roads...click, clunk, bang around turns....and slightly more worn rear tires...
    might do a mechanical rear locker in my 4runner....but it will be driven maybe 4 times a month....
    DD with a mechanical locker....I dunno...save ur pennies IMO
    but totally possible, people have been DD'ing mechanical locker rigs for years :thumbsup:
  10. Jun 27, 2012 at 2:30 PM
    Manwithoutaplan
    ID
    but he is in ca when do we have icy roads :notsure:
  11. Jun 27, 2012 at 2:32 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
  12. Jun 27, 2012 at 2:33 PM
    AsianAnts
    AnT
    so im probably looking at roughly $1,500 if i go the ARB route
    and you are correcct... i wont be on icy roads...
  13. Jun 27, 2012 at 2:33 PM
    jonny
    ever drive up to big bear to wheel?
    :p
    *during the winter
  14. Jun 27, 2012 at 2:34 PM
    Manwithoutaplan
    ID
    yea !!!
  15. Jun 27, 2012 at 2:35 PM
    Manwithoutaplan
    ID
  16. Jun 27, 2012 at 2:37 PM
    Manwithoutaplan
    ID
    yea, but if you do the 3rd member you could have like monkey proof help install it he done it before. So all you would need is parts.
  17. Jun 27, 2012 at 2:38 PM
    jonny
    I dunno...
    I know it's all in the driver...but I'd hate to be heading up hill through the twisty highway in the middle of a snow storm with a mechanical locker in the rear :p
  18. Jun 27, 2012 at 2:41 PM
    Manwithoutaplan
    ID
    i could see mechanical locker being a problem and Abs.
  19. Jun 27, 2012 at 2:41 PM
    AsianAnts
    AnT
  20. Jun 27, 2012 at 2:42 PM
    Manwithoutaplan
    ID
    just got to throw it in Neutral to stop better.
