63" Chevy Frenched Spring Hangers!
Discussion in 'RuffStuff Specialties' started by Dan Fredrickson, Jun 20, 2012.
  1. Jun 20, 2012 at 11:00 AM
    Dan Fredrickson
    Dan Fredrickson [OP] Steel Hauler Vendor
    Dan
    Sacramento/Flagstaff
    '66 FJ45
    These are an evolution of our chassis link brackets but we have taken the ramp to an extreme by boxing it and recessing it into the frame. I know it has been done before but what I have found has always been too small for my taste, I wanted to spread the stress of the frame surgery over a greater area and these are what happened. Both of these make for an absolutely smooth transition from the rock to the rig, no walls in the way!
    A great way to gain all the benefits of 63" Chevy springs with less drag to go with the additional flex they can provide. That has always been the main drawback to using them, mounting the spring hanger forwards on the frame and making it a bigger target than what you started with. Think about adding a pair of Bushed DOM sleeves to french in the shackle hangers to lower the rear also, that can help lower any rig while gaining flex. These require welding to finish and mount, the frame requires cutting to recess the bracket into the frame. These have a 3" ID to fit the larger bushings that come on the Chevy's. The folds on the ends are your pattern for where to cut your frame. These allow for an extremely low profile spring by spreading the ramp over 5", the bracket is 8" long.
    Frenched Chevy Bracket (3' ID)
    Chassis Link Bracket (2 5/8" ID)
  2. Jul 18, 2012 at 8:02 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Easy to do and add a bunch of flex!!!
  3. Oct 2, 2012 at 7:22 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Flex on a budget!
  4. Oct 3, 2012 at 10:12 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    These are not vehicle specific and should work on both. I will see if I can find some pictures for you.
  5. Oct 11, 2012 at 10:24 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A common & very needed upgrade from stock!
  6. Oct 13, 2012 at 3:10 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    An upgrade that is always needed!
  7. Oct 14, 2012 at 10:24 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Yes, 63" chevies are ideal on Tacos, nearly as good as a linked suspension...
  8. Oct 17, 2012 at 9:16 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    An upgrade you can't miss!
  9. Oct 17, 2012 at 9:22 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I not in need of hangers but all the products I bought from RuffStuff are top notch! :D
    :thumbsup:
  10. Oct 24, 2012 at 12:05 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thank you!
  11. Nov 13, 2012 at 10:51 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A favorite among many of our customers!
  12. Dec 3, 2012 at 9:55 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thanks for all of the orders!
  13. Jan 2, 2013 at 10:57 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    These are the REAL DEAL!
  14. Jan 21, 2013 at 10:19 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Hope everyone had a great weekend!
  15. Feb 27, 2013 at 11:37 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    The right way to do!
  16. Apr 22, 2013 at 1:25 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    Mount your springs with confidence with the RUFFSTUFF Frenched 63" spring Hangers!
  17. May 31, 2013 at 10:50 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    It's Friday! Time to hit the trails!
  18. Jun 22, 2013 at 10:51 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Do it right the first time!
  19. Jul 11, 2013 at 10:22 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    The best bang for your buck!
  20. Jul 22, 2013 at 12:53 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    Plenty in stock for you toyota guys!
