65mm to 76mm throttle body swap
Discussion in 'Performance and Tuning' started by 07_prerunner, May 23, 2020.
  1. May 23, 2020 at 3:32 PM
    07_prerunner
    07_prerunner [OP] @project_redhulk on Insta!!
    2007 Red tacoma
  2. May 23, 2020 at 3:39 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    According to the link it’s not compatible with the tacoma
  3. May 23, 2020 at 4:18 PM
    07_prerunner
    2007 Red tacoma
    With a URD TB Adapter going from our stock 65mm to a 70mm or 76mm should work well
    gotoman1969[QUOTED] likes this.
  4. May 23, 2020 at 4:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is literally no point in swapping throttle bodies for a larger unit. Power gains are made inside at the intake air cleaner and the intake manifold itself, not the throttle body.
    Useless mod. Don't bother.
  5. May 25, 2020 at 12:50 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    some way
    somewhere
    some how
    maybe there is a gain
    yet the Engine Control Module will only allow as much as it can meter
    within original design parameters
    more air........ no doubt it will provide more fuel
    until it can't
  6. May 25, 2020 at 6:53 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nope.
    This has been proven on even more high performance engines with dyno numbers. The only thing you may get out of it is snappier throttle, you are better off getting a real tune using HPTuners with amount of coin you'll be dropping for one.
    rmepilot likes this.
  7. Jun 28, 2020 at 6:08 AM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Also, it's more than just an adapter and a bigger TB. Try attaching a 76mm TB to your stock intake designed for a 65mm TB :eek:
