6in lift, steering rubbing frame, i fix this by...?
Discussion in 'Suspension' started by Jkohler, Aug 30, 2011.
  1. Aug 30, 2011 at 11:13 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    My new (to me) 02 Tacoma xcab TDR sr5 has a 6inch lift I bout it with. It has blocks and shackles in the rear and spacer (on top of the coilover) and semi-homemade front control arms.
    It appears the rear is descent, but the front probably needs redone correct. However it is set up? It is causing the steering coming down on the drivers side to rub against the frame and appears to be bent. This is on the top of the fix up list.
    The control arms look like they have been cut and a extension welded between? Looks more garage made than a bracket kit. How much would a new control arm system cost? The swaybar is also lowered the same way with extensions welded between. What's the best way to fix up the front end?
    Any suggestions will help!
  2. Aug 30, 2011 at 11:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  3. Aug 31, 2011 at 5:48 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Wow....we really need to see a picture of the setup in order to tell you how to correct it....
  4. Aug 31, 2011 at 5:52 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah the only way to help is to see pictures...
  5. Sep 2, 2011 at 7:34 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    so after looking around and talking to a few people it seems that i have a discontinued lift from truck outfitters. the top control arm was replaced with a bracket on top of the coil over and instead of the spindle going to the upper ball joint there is some sort of shock. so pretty much no upper control arm and an un needed extra shock thing..
    I've been told i need to get rid of that shit and get a new upper control arm and ball joint. Now the QUESTION. with a 6inch lift do i need to get a new spindle designed for a 6inch lift?
