6inch lift
Discussion in 'New Members' started by Tacomaaaaaaaaaaa, Feb 24, 2017.
  1. Feb 25, 2017 at 10:10 PM
    Tacomaaaaaaaaaaa
    Tacomaaaaaaaaaaa [OP] Member
    Kyle
    2016 silver Toyota Tacoma Trd off road
    Appreciate the help man.
  2. Feb 26, 2017 at 7:47 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    If you want to see one option for a 6 inch lift, check my build thread. I don't have any drive train issues or vibes and off road I can get after it. I got help from a few people on TW and a lot of internet snooping....and MEASURING! Take lots of measurements. Write everything down. Drink lots of beer.
  3. Feb 26, 2017 at 9:00 AM
    Tacomaaaaaaaaaaa
    Kyle
    Bad ass man, your truck looks good. What brand did you go with for the lift? And yeah I'll make sure I got plenty of beer haha.
  4. Feb 26, 2017 at 9:31 AM
    Glueman
    Utah
    The Plague....
    The only thing left from the original Pro Comp 6" lift is the Pro Comp drop brackets and spindles.
  5. Feb 27, 2017 at 10:44 PM
    Tacomaaaaaaaaaaa
    Kyle
    Hey everyone, found out some more info on the 6inch pro comp lift. They say there are no drive train issues with that setup especially if you let someone do it for you. Also re gearing is not essential, it may help with putting 35s but it won't effect much, on the same note putting 33s we will likely not see if a difference if you re gear or not. However on another note... anyone know if people are upgrading there brake rotors to larger ones to componsate for the larger tires?
  6. Feb 28, 2017 at 7:31 AM
    Glueman
    Utah
    The Plague....
    You wont need larger rotors. I'm not even sure they make a larger rotor that would work without causing issues.
  7. Feb 28, 2017 at 7:41 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    I wouldn't consider a 33" a "large" tire. wouldn't need larger brakes, as the truck is too slow anyway.
  8. Mar 17, 2017 at 6:57 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Looks good, I like the wheel on the ruler method to measure, I might have to try that when I trim mine soon. How did you end up doing the actual cutting?
  9. Mar 17, 2017 at 7:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It wasn't me that did the cutting. It was actually @la0d0g so hopefully he can answer your questions.
  10. Mar 17, 2017 at 7:46 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Dremel for the easy spots since I'm more proficient with that tool than others. Body chop saw for the areas by the cab mount.
    JeffRoyJenkins likes this.
