6MT Owners: How Are You Using the Clutch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PandaPandaPanda, Jul 1, 2019.
  1. Jul 1, 2019 at 11:57 AM
    #41
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I agree, I wish we had a better reverse ratio. Backing up a hill with a car full of adults is no problem. Backing up a trailer or boat with ~1000+ pounds kind of sucks.
  2. Jul 1, 2019 at 12:03 PM
    #42
    PandaPandaPanda
    PandaPandaPanda [OP] Well-Known Member
    Alejandro
    2020 TRD OR DCSB
    Does anyone know why they made reverse so tall?
  3. Jul 1, 2019 at 12:05 PM
    #43
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    I heard somebody on here wanted to put a ball on the front end and drive it up that way.
  4. Jul 1, 2019 at 12:07 PM
    #44
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    No good reason that I can think of. Unless it was a packaging issue inside the transmission. It is possible that they couldn't physically fit a better ratio so they just put in what they could. At least that's what I like to tell myself. In reality, I think they just screwed up.
  5. Jul 1, 2019 at 1:01 PM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Our last two MT cars were this way also. I can only think packaging also.
  6. Jul 1, 2019 at 1:12 PM
    #46
    eon_blue
    Azusa, CA
    Sounds like that third one is going to be needing a new clutch soon, probably been used on one too many test drives by people that didn't know how to drive stick. Or maybe someone at the dealership took it home to practice on
  7. Jul 1, 2019 at 2:42 PM
    #47
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Towed 4000 lbs this weekend and backed this up and down some long roads and driveways, can’t tell you how I used the clutch, ancient Japanese secret.
    No accumulator delete, either. Stock as the day I drove it off the lot.
  8. Jul 1, 2019 at 2:44 PM
    #48
    sherwoods_Fleet
    sherwoods_Fleet Well-Known Member
    2019 Cement manual Tacoma+
    Procharger 5.29 Nitro Gears 6 inch RC lift 35x12.50r17 17x9 -38 offset, 3.5 backspacing SCS Ray10s Gunmetal gray. OEM Audioplus sound system Accumulator Delete
    I found the shifting from 1st to second was giving the most “bucking” it started shifting easier when I was making my shifts at 3k rpms and not allowing them to drop below 2k before releasing into the next gear.
    PandaPandaPanda[OP] likes this.
  9. Jul 1, 2019 at 6:05 PM
    #49
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I’m all into trying 3 quarts of the Redline MT90. I’ve just searched the world over for the the OEM Part #s for the two crush washers that I need to do this. Anyone have those part numbers?? I know if i go to the local Toyota parts counter I will be there for an hour unless I have those part numbers in my hand!
    TeecoTaco likes this.
  10. Jul 1, 2019 at 6:08 PM
    #50
    lapoltba
    CT - 06076
    Should be "90430-18008 which is replaced by 90430-A0003".
    Source: https://www.tacomaworld.com/threads/6-speed-transfer-case-and-axle-drain-plug-washers.381674/
    *for 2nd gen, sorry
    Paul631 likes this.
  11. Jul 1, 2019 at 6:09 PM
    #51
    lapoltba
    CT - 06076
    Scratch that, that's for 2nd gen.
  12. Jul 1, 2019 at 6:15 PM
    #52
    hillbillynwv
    Fairmont, WV
    Damn, I thought I had the number, probably the same though.
  13. Jul 1, 2019 at 6:20 PM
    #53
    lapoltba
    CT - 06076
    It may be, but I am not sure. It's just a crush washer and you can probably get one equivalent at most auto parts stores.
  14. Jul 1, 2019 at 6:22 PM
    #54
    sherwoods_Fleet
    If you have a hard time getting it to go into first at a dead stop, release the clutch and push it in again. Usually it allows first to engage.
  15. Jul 1, 2019 at 6:26 PM
    #55
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Transmission
    Manual Transmission Drain/Fill Gaskets (Part #90430-A0003 x 2 gaskets for Transmission)
    Drain/Fill Plug Torque to 27 lb-ft
    Redline MT-90 75W90 GL4
    (2.6L approx), SAE 75W-90 - Redline or Amsoil API 75w-90 GL4
  16. Jul 1, 2019 at 6:28 PM
    #56
    lapoltba
    CT - 06076
    Just so I know, where did you find that? I'm assuming it's in a thread here on TW? I want to bookmark it for when I change my fluid.
    TeecoTaco[QUOTED] likes this.
  17. Jul 1, 2019 at 6:30 PM
    #57
    TeecoTaco
    SW Ontario
    shakerhood likes this.
  18. Jul 1, 2019 at 6:31 PM
    #58
    lapoltba
    CT - 06076
  19. Jul 1, 2019 at 6:31 PM
    #59
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    That’s mine! lol
    I did my maintenance not long ago, I am “self certified” technician :D
    it’s all correct parts, you are good to go.
  20. Jul 1, 2019 at 6:33 PM
    #60
    TeecoTaco
    SW Ontario
    Reciprocation for a nice 2LM!
    tonered likes this.
