6SP Clutch Fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris24, Jun 26, 2013.
  1. Jun 26, 2013 at 9:07 AM
    Chris24
    Chris24 [OP] Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Wanting to get my clutch fluid replaced soon...what do you 6sp guys reccomend? 55k on the odometer.
  2. Jun 26, 2013 at 9:14 AM
    Manwithoutaplan
    ID
  3. Jun 26, 2013 at 9:35 AM
    Chris24
    Greensboro, NC
    are you recommending that for clutch fluid or trans fluid? i already have that in my trans
  4. Jun 26, 2013 at 9:49 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Clutch fluid is just DOT 3 brake fluid. DOT 4 is fine, it just has a higher boiling point than DOT 3.
  5. Jun 26, 2013 at 9:57 AM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
  6. Jun 26, 2013 at 9:58 AM
    Chris24
    Greensboro, NC
    is there a write up here how to change both?
  7. Jun 26, 2013 at 10:44 AM
    ailll1
    Alex
    Québec, Canada
  8. Jun 26, 2013 at 10:46 AM
    Manwithoutaplan
    ID
    i think he has split because he does not have atrac.
  9. Jun 26, 2013 at 12:24 PM
    Chris24
    Greensboro, NC
    only one reservoir
  10. Jun 26, 2013 at 2:58 PM
    ailll1
    Alex
    Québec, Canada
    That's the method I use: http://www.youtube.com/watch?v=V5O_pbC8R2E
    There really is nothing different between changing clutch fluid or changing brake fluid. The process is the same.
    The bleeder for the clutch is on the driver side of the tranny.
    And make sure to check the fluid level in the reservoir really often so it doesn't become empty. If it does, you might get air in the ABS system and that won't be fun to bleed afterwards.
