6spd Clutch Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11Tacos, Apr 25, 2023.
  1. Apr 25, 2023 at 9:02 AM
    11Tacos
    11Tacos [OP] New Member
    2011 DCSB 6spd
    Hello TW first time post but I've read everything I could dig up on the RA60F 6 speed issues...currently my '11 Taco does not shift into any gear at a stand still w/ engine running. Engine off shifts into every gear. If I get the truck rolling I can force it in but it's difficult. I've read about the TOB issues but my truck doesnt squeal in neutral at all and once I'm rolling it doesnt slip/pop out/ or get stuck. Just seems I'm not getting full engagement from the clutch pedal. I've replaced master and slave and thoroughly bled, adjusted the master rod, checked for cracks in the pedal bracket, and not coming up with anything. I've seen many other posts with these symptoms but most were related to TOB and fork. My fork doesnt seem to be cracked and is definetly moving back and forth. Any help is appreciated.
    I believe its stock clutch 150k miles
  2. Apr 25, 2023 at 9:04 AM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    Might be time for a clutch job... that is about all that is left that could be wrong.
    11Tacos[OP] likes this.
  3. Apr 25, 2023 at 9:14 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Something is making the clutch disc spin slightly.... or alot... so it's not de-clutching. Something as simple as the disc hub is not sliding freely on the input shaft splines, so maybe the disc is still getting spun by the flywheel.
    My 2005 with 6 speed is approaching that issue. At a stop, as I depress the clutch pedal, and then select 1st, I feel a slight jerk forward. With 220k and 18 years on the original clutch, it's due, even though it drives and holds full throttle still. Had an Aisin clutch on the shelf for a few years, it's gotta happen soon for me.
    When you have the clutch done, or do it, use a wire brush or wire wheel to make sure input shaft splines are very clean from rust and goo.
  4. Apr 25, 2023 at 12:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Either it isn't disengaging when the pedal is pressed (lack of movement) or the pressure plate is shot.
