6spd clutch noises
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, Feb 10, 2011.
  1. Feb 10, 2011 at 7:58 AM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    I have a 2010 Tacoma 6spd with around 15,000 miles
    Lately I’ve been noticing noises (squeaky and springy) from my clutch when I engage/disengage the clutch. Its been more noticeable when the weather is warm.
    Ive read of some stories on here regarding this. Is it the throwout bearing? It should be covered under warranty? How long does it usually take them to fix this issue
  2. Feb 10, 2011 at 8:05 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Squeaky pedal is common..especially in warm weather. Whoever thought it would be a good idea to use a plastic pedal arm should be shot.
    I spray white lithium grease on it when it starts squeaking and it usually goes away for a month or two.
  3. Feb 10, 2011 at 8:26 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    dang..my truck only has 15,000 miles
  4. Feb 10, 2011 at 8:46 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    well are you hearing the clutch pedal or the throwout bearing? He's sayin throw out bearing. That would only make noise when engine running.
    Its a new "toyota" so the bearing could be bad in the box, as it were. They let the drivers do the QC now, like GM used to.
  5. Feb 10, 2011 at 8:48 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    TOB is more or less a "chirp" in my opinon and goes away (generally) when the clutch is pushed in... I took my to the dealer and it wouldn't "chirp" but they documented it and I'm going to take it back when it does it again ( it does it off and on).
    Az
  6. Feb 10, 2011 at 9:10 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    im hearing it from inside the cabin so its def the pedal...
    makes me want to sell the 6spd and get an auto..
  7. Feb 10, 2011 at 9:16 AM
    matt1381
    matt1381 Well-Known Member
    Independence, KY
    05 4x4 SR5 TRD
    OME 885 Front Coils All Pro 3 inch Leaf Springs 285 75 16 Pro Comp All-Terrains
    I have a 2005 and it made the same noise. You can take it back to the dealer and they will fix it. They replaced a part on mine and it hasn't made that noise in a couple years. It's covered under your warranty. It wasn't the throw out bearing.
  8. Feb 10, 2011 at 9:33 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I have a 2010 6 speed. And finally figured out what the little squeak is. The Driver's seat, take the seat out and there are 2 pointy things on the bottom of the seat. They are guides for putting the seat in at the Factory. cut them off, put the seat back in squeak is gone.
  9. Feb 10, 2011 at 9:34 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    lube.
    study the mechanism on the cabin side. see what pivots and where things are moving in holes, even the return spring holes. then cover the floor and firewall with paper or cardboard or both, and take a true quality grease (like BG ss2000) and hit the spots with it. for the spots you can't get to, take a true penetrating oil (not WD-40, something like BG In-Force) and spritz those spots.
    do these trucks have a normal clutch master cylinder? i haven't even looked. if so, it could be that, as that is a problem on some vehicles like 8th gen honda civic si. but i'd bank on the pedal mechanism needing some spot lubing.
  10. Feb 10, 2011 at 9:42 AM
    island808
    Jedediah
    hawaii
    WOW.. I'll be the first to admit.. carrying over toyota's name on the american made ones is insulting to the japan made vehicles...
    But, you need to maybe just solve your squeak. Everything can be de-squeaked. And in this case, its your dealers job. If its the pedal, It should be fairly easy. Though it may involve removing it. Spraying it down shouldn't work, if its the axle or spring mount doing the squeaking.
    as a teenager I was the squeak and rattle guy (no skills to speak of at the time) and customers came in for a lot less than that and my service manager wouldn't accept anything short of fixed.
