6spd hunting for rpm while in motion??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinjeanlucphina, Mar 10, 2014.
  1. Mar 10, 2014 at 3:32 PM
    kevinjeanlucphina
    kevinjeanlucphina [OP] New Member
    mike
    nh
    2007 v6 6spd
    one inch up front, bags out back
    Gentleman, I am a happy owner of 2007 V6 Spd Tacoma. Warm or cold, same symptoms. No ground speed truck will idle to appropriate 750 rpm and will maintain correct idle speed. Allow vehicle to increase ground speed while in nuetral, about 12 mph engine rpm begins to fluctuate. Has gotten worse over time, nearly heading past 2000 rpm at some points. Definetly part of ecu recognizing truck moving forward. Have not tried moving reverse?? Any one unplugged speed sensor on trans??
  2. Mar 10, 2014 at 3:43 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    that doesnt make sense. you have a manual transmission, its not like it has converter drive or lock up.. its just.. flywheel, clutch, transmission. if your rpms are going up while a gear is engaged... your clutch is not holding to the flywheel. i hear the throwout bearing is a weak point.. but any fluctuation in RPMs with the cluch out means its no workie.
    hows it do past 12mph?
    edit:
    wait in neutral? i mean.. ive heard of the rev hang.. how long does it stay up at 2000? are you pressing in the clutch or putting the trans in neutral? and at higher speeds?
    edit2: if youre pressing the pedal in, are you sure the clutch is completely disengaging? try putting the stick in neutral with the clutch out?
  3. Mar 10, 2014 at 4:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Ground Speed?
    Can your Tacoma Fly?
    How can you increase "Ground Speed" while in neutral? If you mean that you speed up in gear and then press the clutch the engine idle remains high for a second or two. That is normal.
  4. Mar 10, 2014 at 4:17 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    x2 ^^ OP description makes no sense. Sounds like clutch is worn out and slipping if rpm is changing while in gear and driving.
  5. Mar 10, 2014 at 4:24 PM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    Are you getting and grinding in the gears when shifting? Transmission may not disengaging completely. Check clutch your clutch fluids.
    Bacon
  6. Mar 10, 2014 at 4:36 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I think all he's saying is if the vehicle isn't moving it idles normal. When the vehicle is in motion and it's out of gear the the rpms fluctuate.
    When I had my 6 speed something similar would happen, but in slightly different situation. When getting off highway ramps after driving for a while, if I took it out of gear and left it in neutral, the engine rpm would go up and down between idle and 2000 rpms. Then it would calm down after a bit and act normal. It did that from new.
  7. Mar 10, 2014 at 4:50 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    My 4 banger does this if Im coming down off of a long steep mountain grade.
  8. Mar 10, 2014 at 7:14 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Mine will do this too, though usually it holds about 1200RPM when in motion in neutral. Since there in no good reason to use "Mexican Overdrive", and enough very good reasons to not coast in neutral, its not a big deal.
    If the throttle cuts in and out while driving in gear, it could well be a problem with the stop lamp switch - either adjustment or a faulty switch engaging the brake override on the drive-by-wire throttle.
  9. Mar 10, 2014 at 7:20 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Gotta love cryptic first posts with no follow up. :confused:
  10. Mar 10, 2014 at 7:23 PM
    moondeath
    Pa, Gardners
    Sounds like maybe this is common then.
    "Mexican Overdrive" LOL, I had to look that up.
  11. Mar 10, 2014 at 7:54 PM
    worthywads
    Hmmm, my Mexican overdrive works great.
  12. Mar 11, 2014 at 5:32 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  13. Mar 11, 2014 at 5:38 AM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    :poking: I guess my post to his other posted did help, lol.
  14. Mar 11, 2014 at 6:48 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  15. Mar 11, 2014 at 6:50 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    He's a great troll...
  16. Mar 11, 2014 at 12:14 PM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    I hope this isn't too much of an amateur question...
    Just out of curiosity, what are some of these reasons? I can't say that I normally coast in neutral while driving, though I'll certainly drop it into neutral if I'm approaching stop and then just coast to a stop from time to time.
    I understand it's not good to coast with the vehicle in gear and clutch depressed, but why in neutral?
  17. Mar 11, 2014 at 7:55 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    -Higher fuel consumption when coasting in neutral compared to using engine braking where the ECU shuts off the injectors during deceleration (fuel cut-off).
    -More brake wear from not using engine braking.
    -Less control - say you saw a vehicle about to tee-bone you at the last second, and flooring it to get out of the way would avoid the accident - it won't work in neutral. A bit hypothetical I agree, but the gas pedal can be the safest way to avoid a collision in rare occasions.
    What you describe won't cause any catastrophic damage for sure.
  18. Mar 11, 2014 at 7:58 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    I've heard of at least two cases of a faulty or misadjusted stop lamp switch causing throttle trouble here on TW, and you're absolutely correct, no DTCs.
  19. Mar 11, 2014 at 8:23 PM
    transplant
    theo
    Crestline, Ca
    whats a dtc and stop lamp sw?
  20. Mar 11, 2014 at 9:16 PM
    transplant
    theo
    Crestline, Ca
    it makes so much more sense now! thanks!
