6spd Manual take off shudder and clunks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wyotacotrd, Apr 1, 2016.
  1. Apr 1, 2016 at 3:16 PM
    wyotacotrd
    wyotacotrd [OP] Well-Known Member
    Cade
    Laradise, Wy
    White 2012 DCSB TRD Offroad v6
    Fox 2.5 Remote Resevoir Coilovers, SCS Ray10 bronze, IVD progressive AAL, Fox 2.0 Remote Resevoir rears, Wheelers OR bump stops, Prinsu design studio cabrac, Softtop in Tan, etc...
    Hey guys, I just got back from moab which was a 14 hour drive in my "new" 2012 tacoma that I have had for just over 3 months. The truck travels great on the highway and interstate, and has enough power for anything that I need. I have been hearing about other people having acceleration vibrations/shudders after installing a lift, but do other people who are stock have this problem? My stock truck in 1st-4th will shudder really bad if I give it more than 1/4 throttle, also when I am in 4th-6th going faster than 50mph, when I take my foot off the throttle and then put it back on I have a really jarring thunk. Is this normal, and are the two problems associated? Can i expect worse when I install my lift, even with axle shims and a CB drop? Thanks for any help.
  2. Apr 1, 2016 at 3:23 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Sounds to me like a worn out carrier bracket bushing, or worn out U joints.
    With a lift, you might have no problems, you might have lots. Be prepared to do a lot of tweaking and trying different things. Axle shims+CB drop might work, or it might be no axle shims and a very short CB drop. I ended up with axle shims and an extended CB drop (using fender washers), which left me with only a small vibration right at 20 mph.
  3. Apr 1, 2016 at 3:38 PM
    wyotacotrd
    Cade
    Laradise, Wy
    The problem is is that my truck only has 25k miles on it. Could stuff really be worn out by now?
  4. Apr 1, 2016 at 6:38 PM
    wyotacotrd
    Cade
    Laradise, Wy
    Anyone else?
  5. Apr 1, 2016 at 6:42 PM
    skootx
    Erie, CO
    Probably not U joints then, but the carrier bearing bushing is rubber and could have dried out. Get under there and see if there is any play at the CB.
  6. Apr 1, 2016 at 8:27 PM
    wyotacotrd
    Cade
    Laradise, Wy
    So I just got home and crawled under the truck. The rubber feels and looks good, but there is definitely some play in the cb within the rubber ring, but I have to pressing pretty hard for it to move. Should there not be any play at all, no matter how hard you push?
  7. Apr 1, 2016 at 9:11 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The cb will have some movement under pressure, from what you stated, the next thing to check would be the u-bolts (lots have said they are under torqued from the fact.) torque them to 80ft-lbs (IIRC) and see if that helps.
  8. Apr 2, 2016 at 1:21 PM
    wyotacotrd
    Cade
    Laradise, Wy
    So I just greased 3 of the u bolts with some random grease that was in my gun, I think axle grease, and the truck drives alot smoother, I was still getting some shudder about 20 mph but it isn't through 4th gear like it used to be. I also only got it up to 65 in 5th and 6tb and felt for the clunk, and I still felt a little something in 6th but 5th was smooth as butta. Could dry u bolts really have been causing all of that? I'm probably gonna get some better grease later this week.
