6Spd Manual Tranny problems!!HELP!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ruizbau2699, Jul 28, 2019.
  1. Jul 28, 2019 at 5:58 PM
    Ruizbau2699
    Ruizbau2699 [OP] Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    So just the other day I was in my driveway getting ready to pull out and put my truck in first gear and start letting out the clutch and started moving and all the sudden just stopped it didn’t stall I quickly put the clutch back in and put it in 1st and went along fine then happened in a drive thru then parking lot its not a grinding noise at all sounded like brakes really bad breaks scraping but I never had the foot on the brakes don’t know what’s going on really scared what damage it might be and I’m still under warranty hasn’t been a year but got 11500k miles on it hoping Toyota doesn’t do a BS call saying my exhaust or lift or new grill has anything to do with it
  2. Jul 28, 2019 at 5:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That sounds like your TRAC going off to control wheel spin?
  3. Jul 28, 2019 at 6:00 PM
    Ruizbau2699
    Noe
    But I’m not even giving it gas I’m just using the clutch and easing out
  4. Jul 28, 2019 at 6:02 PM
    Shellshock
    Iowa
    Wheel spin? On a 3rd gen? Come on, everyone knows that can’t happen!
  5. Jul 28, 2019 at 6:08 PM
    su.b.rat
    su.b.rat broken truck
    OP are you currently getting some symptom or problem, or was that a one time thing? I'm not clear on what's going on.
    Junkhead likes this.
  6. Jul 28, 2019 at 6:10 PM
    Ruizbau2699
    Noe
    Truck drives fine and 1st engages fine but it’s only happened 4 times in the past two days started yesterday
  7. Jul 28, 2019 at 6:12 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Probably not fully in gear and grinding a bit
    doublethebass, Txexplorer and bigmw like this.
  8. Jul 28, 2019 at 6:13 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    How long have you had the lift? Could be the parking brake cable is too tight.
  9. Jul 28, 2019 at 6:14 PM
    Ruizbau2699
    Noe
    I don’t think so i make sure it’s fully engaged in 1st position I’ve grinder gears in my 1st gen before and that’s definitely not it
  10. Jul 28, 2019 at 6:16 PM
    Ruizbau2699
    Noe
    It’s just a leveling kit maybe 1k miles and the parking brake actually feel like it’s getting loose
  11. Jul 28, 2019 at 6:16 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    That was hard to read, holy shit.
  12. Jul 28, 2019 at 6:24 PM
    daddy_o
    Bossier City, La
    Its gotta be the grille then.:rofl:
    Seriously though, is there anything you can do to make it happen or is it just random? Also, if you could get a video of the noise or close in if its the front or back that would help.
  13. Jul 28, 2019 at 6:29 PM
    Ruizbau2699
    Noe
    It’s only happened when i sit while the truck is running then pull out other then that any other time it’s fine and it’s only 1st gear reverse and the rest are fine
  14. Jul 28, 2019 at 6:30 PM
    Ruizbau2699
    Noe
    I’ll see if I can’t get some kind of video for y’all
  15. Jul 28, 2019 at 6:34 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Sorry guys interwebs screwed up, I got all his punctuation.
    Chako, Bray, whitebread and 12 others like this.
  16. Jul 28, 2019 at 6:42 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
  17. Jul 28, 2019 at 6:49 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Lift details? Damaged speed sensor/wire can cause traction control to do strange things.
  18. Jul 28, 2019 at 6:50 PM
    Ruizbau2699
    Noe
  19. Jul 28, 2019 at 6:51 PM
    ajmogen
    Aaron
    Wisconsin
    No uca's?
  20. Jul 28, 2019 at 6:53 PM
    Ruizbau2699
    Noe
    Nope just a 2.5 leveling strut spacer
