.:-- 6th Annual KY/TN March 2018 Land Between the Lakes Meet--:.
Discussion in 'Tennessee' started by allmotorrex, Nov 27, 2017.
  1. Feb 24, 2018 at 8:08 PM
    #1101
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    Just signed up for a year
  2. Feb 24, 2018 at 9:12 PM
    #1102
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I use MotionX also. They both have their plusses and minuses.
  3. Feb 24, 2018 at 9:12 PM
    #1103
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    You can get topographical maps free, never tried satellite.
    beertimecontinuum likes this.
  4. Feb 24, 2018 at 11:00 PM
    #1104
    Kenstaroni
    Kenstaroni Well-Known Member
    Ken
    Nashville, TN
    2018 T4R TRD Offroad
    Icon Stage 2 285 KO2's RCI Sliders Rhino Rack Pioneer CB
    You can add maps, it will give you an adjustable search area in red. They take a while to download, especially when it's a lot of tiles, but you'll have GPS location and the map, no 4G or Wi-Fi needed as long as your device has a built in gps.
    I use the record feature a lot and it logs the route, stops, distance, and a whole bunch of other info.
  5. Feb 25, 2018 at 2:45 AM
    #1105
    2TRunner
    2TRunner Snoop Dad
    My House Usually
  6. Feb 25, 2018 at 6:44 AM
    #1106
    presta24
    chris
    Cincinnati
    I have a set of lower grill brackets and a 32" light bar I can bring to the meet if any one is interested. Not sure brand of the light bar. Both are NIB. $75.
  7. Feb 25, 2018 at 7:00 AM
    #1107
    presta24
    chris
    Cincinnati
    I dont think so
  8. Feb 25, 2018 at 7:34 AM
    #1108
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Can light bars be wired to the Foglights?
  9. Feb 25, 2018 at 7:51 AM
    #1109
    Harri Ant
    Harri Ant Active Member
    2017 Tacoma 4x4 O/R
  10. Feb 25, 2018 at 7:54 AM
    #1110
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
  11. Feb 25, 2018 at 8:04 AM
    #1111
    2TRunner
    2TRunner Snoop Dad
    My House Usually
  12. Feb 25, 2018 at 8:06 AM
    #1112
    mwc273
    mwc273 Nothing is as it seems.
    Yes. But it's not advisable.
    Because then you would never be able to use your fog lights on the road. Keep them separate so you can use your fogs in the fog in traffic and then when you're Offroad you can turn all the lights on.
  13. Feb 25, 2018 at 8:07 AM
    #1113
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Probably while you were out smoking... o_O:rolleyes::boink:
    beertimecontinuum and mwc273 like this.
  14. Feb 25, 2018 at 8:13 AM
    #1114
    allmotorrex
    allmotorrex [OP] Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I gotcha on there. You gotta name?
  15. Feb 25, 2018 at 8:28 AM
    #1115
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Shush. No one knows.
  16. Feb 25, 2018 at 8:28 AM
    #1116
    Harri Ant
    2017 Tacoma 4x4 O/R
    Yep got one of those! It’s Harry, thanks brother
  17. Feb 25, 2018 at 8:46 AM
    #1117
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    Thanks. That’s almost the only time I use them. It’s a courtesy thing.
  18. Feb 25, 2018 at 8:49 AM
    #1118
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Knows what??? o_O
  19. Feb 25, 2018 at 8:51 AM
    #1119
    mwc273
    That the roundidity is directly proportional to the diameter of the circumference. o_O
  20. Feb 25, 2018 at 8:59 AM
    #1120
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    X radius°
