6th gear is a joke!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Señor, Jan 12, 2021.
  1. Jan 12, 2021 at 10:17 AM
    Señor
    Señor [OP] Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    Besides always driving in S mode is there any mods to avoid 6th gear engaging? It seems to be a useless gear unless you're traveling on a long level road, because at any sign of the slightest uphill grade it downshifts one sometimes two gears. And it seems like the transmission is in a hurry to shift as quickly as possible into 6th.
    Yeah and before some of you say "get a manual", I didn't want one!
    soundman98, pwgunny and helix66 like this.
  2. Jan 12, 2021 at 10:19 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Re-gear to 5.29's it will make you fall in love the 6th gear!
    daltondrose, Mully, Skydvrr and 5 others like this.
  3. Jan 12, 2021 at 10:19 AM
    Tacospike
    Two Trucks
    knock knock
    Who's there?
    6th gear
    6th gear who?
    *shift sound*
    Hi, I'm 5th gear
    :rimshot:
  4. Jan 12, 2021 at 10:21 AM
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    If you had a 19 I'd say go get the new TSB... it's amaze-ballz
    cbouch001, Junkhead and Chunk like this.
  5. Jan 12, 2021 at 10:22 AM
    Señor
    CA Central Coast
    You need to do both front and rear when you re-gear, correct?
    boston23 likes this.
  6. Jan 12, 2021 at 10:22 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I'm not going to say anything.:deadhorse:
    MadKatt, Silentshredr and RedWings44 like this.
  7. Jan 12, 2021 at 10:23 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Sixth gear does amazing stuff for me on my frequent drive down the I-17 from 7,000 ft to Sea Level. Back uphill is S4 anyways, so I am glad that sixth is there for me on the way down.
  8. Jan 12, 2021 at 10:24 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Correct. I was joking a bit, however; I don't know of any way to keep it out of 6th without S mode.
    Junkhead likes this.
  9. Jan 12, 2021 at 10:24 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    :pout:
  10. Jan 12, 2021 at 10:25 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    That's literally what S5 is for.....
    Silentshredr, Skydvrr, Chew and 2 others like this.
  11. Jan 12, 2021 at 10:25 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    I feel having the transmission in ECT mode helps reduce the amount of shifting between gears.
    cryptolyme likes this.
  12. Jan 12, 2021 at 10:26 AM
    GreyBaldTaco
    2019 F150 5.0
    It changes the shift points.
  13. Jan 12, 2021 at 10:28 AM
    Camby
    Brian
    Denver
    Yes I know, and those shift points IMO are better than the standard shifts point, as each gear has a larger/broader RPM levels.
  14. Jan 12, 2021 at 10:29 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Mine works great
    MadKatt, Chew, RedWings44 and 2 others like this.
  15. Jan 12, 2021 at 10:29 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Ok I won’t say trade it for a manual, but the gears in the manual make a huge difference
    Kev250R, Junkhead and Redeemed like this.
  16. Jan 12, 2021 at 10:33 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Only way is to keep in S mode. Otherwise it’s gunna try 6th.
    how fast are you going on the freeway?
    $$ options:
    Try Ov tune
    Or try regearing 4.88 (looks like your tires are close to stock size)
    Junkhead and Malvolio like this.
  17. Jan 12, 2021 at 10:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You have a 2018 - look into getting your ECU updated to the latest version. And if that doesnt work, look into VFTune.
    I cant believe that I'm the first person here to say that.
    Edit: 2nd person. Missed it by that much.
    https://www.youtube.com/watch?v=qZOGlgVldAs
  18. Jan 12, 2021 at 10:34 AM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Beat yah :p
  19. Jan 12, 2021 at 10:36 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    I went with the all in option!
    Rock Lobster[QUOTED] likes this.
  20. Jan 12, 2021 at 10:36 AM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    Easy just don’t hit the clutch and shift into 6th.
