6th gear is a joke!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Señor, Jan 12, 2021.
  1. Jan 12, 2021 at 10:38 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    No problems here, and I live in the mountains..
    Junkhead and Grossomotto[QUOTED] like this.
  2. Jan 12, 2021 at 10:40 AM
    Señor
    Señor [OP] Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    Mine is a '18 and I did get the TSB done. It helped with the constant hunting and the surging. But on the freeway here, it's all level changes, and yes it does fine in S-5, and the mileage isn't too much affected. So, now I don't really use the regular Automatic unless the roads change to long and flat out towards the desert areas, or short errands and in the city driving. But in most of my driving 6th is annoying to me. Guess I just needed to vent.
    Love the truck though!
    EDIT, as you stated maybe another update/later is available I'll look into that. It needs to go in got the fuel pump thing anyway.
    Chunk likes this.
  3. Jan 12, 2021 at 10:48 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    This may not be the answer you are looking for, but you might find the most satisfying thing is to get the latest ECU update and then learn to accept the transmission for what it is.
    I’ve mentioned before that this is an issue on mountain bike forks where you have riders trying to reconfigure their compression and dampening to match what they got used to in 2004 instead of learning the way their new $1,000 fork operates and “feels.”
    What did you drive prior to 2018? That might be telling.
    TacoPandaTRD likes this.
  4. Jan 12, 2021 at 10:52 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    OP, 6th gear is for going down the hills only. The other five are for going up hills. Evrbody knows that....
  5. Jan 12, 2021 at 10:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The 2017 MTs, 2019 ATs, and 2020s have received pretty much the same updates recently. The 2016 ATs and 2018s have not seen a similar update since the one that was released in the middle of 2018. Keep an eye out either for an update / revision to the newer TSBs (TSB-0043-20 or TSB-0092-20) or maybe a new one to cover these remaining Tacos?
    Bleep100 and Junkhead like this.
  6. Jan 12, 2021 at 11:25 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Please do tell...;)
    Did you get in your truck by the way?
    Bleep100 likes this.
  7. Jan 12, 2021 at 11:28 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Yeah, just called AAA lock service, forgot I had it since I never use it.
    Bleep100 and Junkhead[QUOTED] like this.
  8. Jan 12, 2021 at 11:36 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I like 6th :notsure:
    Junkhead and Bleep100 like this.
  9. Jan 12, 2021 at 11:50 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Me too.
    Bleep100 and RedWings44[QUOTED] like this.
  10. Jan 12, 2021 at 12:05 PM
    Señor
    CA Central Coast
    Porsche Cayman S, BMW 335, Honda CBR600R and 85 Toy 4X4 Xcab 22-R
  11. Jan 12, 2021 at 12:17 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Don't worry, 6th gear is just as useless on the manual transmission.
    ian rogers and Vlady like this.
  12. Jan 12, 2021 at 12:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    You cant be serious sir.
    I even use it in city driving.
    MOC221_ likes this.
  13. Jan 12, 2021 at 12:34 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It works fine in my tacoma, but driving in the ECT mode locks out 6th gear. I guess its normal for towing...you wouldn't need 6th pulling a trailer.
  14. Jan 12, 2021 at 12:40 PM
    Oldtruckguy
    Oldtruckguy Active Member
    2021 White Tacoma OR-AC
    Works perfectly on my ‘21 OR and there is hardly any flat land around here.
    Junkhead likes this.
  15. Jan 12, 2021 at 12:41 PM
    #35
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    ill take your 6th gear sir.
    cruising at 2800rpms on the freeway gets old
  16. Jan 12, 2021 at 12:42 PM
    #36
    AMC-FF17319
    AMC-FF17319 Well-Known Member
    Andrew
    Gray, ME
    2016 Silver Tacoma TRD OR Access cab
    OME 2", Victory 4x4 all over, 5.29 gears, SPC UCA
    No $2k stimulus let me down in this regard... hoping to do this myself soon
    Chunk[QUOTED] likes this.
  17. Jan 12, 2021 at 12:47 PM
    #37
    jmneill
    SE
    lol
  18. Jan 12, 2021 at 1:08 PM
    #38
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    2021 AT owner here. I live in a mountainous/hilly region and it definitely does like to shift in and out on any incline. Also likes to try and shutter/buck if you're going slow (40-45mph ish) and barely tipping in the throttle. Super annoying, but I'm slowly getting used to it. Only thing I don't like about the truck, honestly. I came from a 2009 4.0 with the 5 speed automatic, just thought I hated that transmission till I bought this truck.
  19. Jan 12, 2021 at 1:23 PM
    #39
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    You are spoiled by fancy transmissions! Sweet.
    Señor[QUOTED][OP] and tonered like this.
  20. Jan 12, 2021 at 1:31 PM
    #40
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Why I got a manual the auto is garbage .
