6th gear whine / whistle only when pressing accelerator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by asjenkin, Aug 19, 2012.
  1. Aug 19, 2012 at 6:20 PM
    asjenkin
    asjenkin [OP] New Member
    Adam
    I have seen a lot of people talk about this, but no answers. Does anyone kow why the taco whines when I push on the gas at around 60-70 mph. Noise goes away when I let off the gas pedal. It is not the windshield, front grill, wheel alignment, tires... Not sure if it has something to do with the transmission or clutch... Can anyone help. Also anyone searching I was getting gear grind going from 2nd to 3rd switched to Redline MT 90 and shifting good now. Still not perfect but no grinding at least. I really hope Toyota recalls the transmission but I don't think it will happen now.
  2. Aug 19, 2012 at 6:50 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    A throttle dependant whine is an indicator of a preload issue on the diff pinion bearings. I'm not saying that is your issue for certain, just one of the first things I'd check. Put the transmission in neutral with the park brake on, wheels blocked, and grab ahold of the input flange on the diff. If you can get any play in the bearings you have found your culprit.
  3. Aug 19, 2012 at 7:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I get this too sometimes, only in 6th. Not diff or driveline related.
  4. Aug 19, 2012 at 7:28 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Mine is different. I get the whistling noise when I let off the gas around 65mph, and it goes away when I touch the gas. It doesn't make the noise if I put it in neutral and coast at that speed.
  5. Aug 19, 2012 at 7:31 PM
    Goflight2
    Goflight2 Well-Known Member
    Southern Cal
    Supercharged 2011 4x4 LB
    TRD Supercharger Snug top SL Window Tint 5% rear, 35% front, 40% windshield Avid Off Road bolt on sliders Andres Toyota Horns Hard-wired Garmin Nav Weather Techs 5100's in front Rear TSB Bed Extender OEM Roofrack TRD Exhaust Ultra gauge 18" Monster XD's on Nitto Terra Grapplers
    Mine whistles when I punch it!
  6. Aug 19, 2012 at 7:51 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    my first gear whines like a mofo. reminds me that i have gears not some planetary goof-ball setup
  7. Aug 19, 2012 at 7:53 PM
    Blkvulcan
    Blkvulcan Well-Known Member
    Paul
    Augusta, GA
    12 Prerunner SR5
    Not even sure it's possible, but could the 6th gear be straight-cut?
  8. Aug 19, 2012 at 7:54 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Someone linked a video in that thread about that guys Tundra whose engine blew at 98k miles, anyways he said the whine sounded like a pulley issue but really has something to do with the oil pump. Idk I'm just saying this in case someone knows what I'm talking about. I'll try to find the video to see if it's similar
  9. Aug 19, 2012 at 8:02 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
  10. Aug 19, 2012 at 8:25 PM
    92dlxman
    Kevin
    Visalia, CA
    i know what your talking bout 503. i hope to god nobody personally experiences that whine. . . . .i actually had a nightmare about it a couple nights ago.
    to be more serious than my last post op, (im sorry if i came across rude) but if your fluid levels are good, and the oils are fresh, i wouldn't worry about it until it manifests into a more obvious problem. landphil has a good answer but if that is not your problem then you may be driven insane trying to figure it out.
    to be less specific than he was, get under there and start yankin on stuff, take note of any slop that may be questionable in the drive line and report back. do this only after you are sure you have good oils in all drivetrain components
  11. Oct 1, 2012 at 6:08 AM
    pcaliri
    pcaliri New Member
    Pete
    Massachusetts
    2012 Tacoma Off-Road Package - NEW Tacoma #4
    Plastics, tint, starter & looking to add more
    My 2012 OFF-ROAD does the same thing around 75-85 mph. I thought it was my A/C fan since it sometime shut off but it also could be that I wasn't accelerating. Sounds like it comes across the windshield or front end. I also suspected that it was cross-wind on the highway.
    I have about 6500 on her now and the issue hasn't stopped. Haven't mentioned it to the dealership yet.
    HELP!
  12. Oct 1, 2012 at 6:42 AM
    leveltwo
    leveltwo Well-Known Member
    I have the same issue, dunno what it is...
  13. Oct 1, 2012 at 12:40 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    can also be the ISB, although its more of a rattle it can feel/sound like a whistle some times
  14. Mar 12, 2013 at 1:39 PM
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    I get a whine around 70-80 mph (2012 TRD Sport) only when i have my foot on the accelerator. It disappears completely when i let off. I thought it sounded like it was coming from the back of my truck which i thought might be an issue with the fuel pump? I was hoping to find something on here but looks like no one has a clear idea of what it is? I guess i can check with the dealer. Around 8k miles on the odo.
  15. Mar 13, 2013 at 6:42 AM
    asjenkin
    Adam
    Please let us know what you find out. I can't figure it out. Just living with it for now.
  16. Mar 13, 2013 at 7:28 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    I get it in 4th and 6th
    Vegg8 likes this.
  17. Mar 13, 2013 at 1:07 PM
    daggs81
    CT Shoreline
    2017 TRD Sport
    This noise is deff not normal, im not sure if i have the same problem as others on this post but this noise should not be happening. It is not a gear type noise like you would hear in reverse, it is a high pitch whine noise. I don't know what kind of car or truck would it be normal to hear this noise in?
  18. Mar 13, 2013 at 1:08 PM
    daggs81
    CT Shoreline
    2017 TRD Sport
    Mine is auto btw, i only hear it above 70mph so it would be in 5th gear for me.
