7/8" by 1.5" rectangular Pressure Gauge?
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by helibear, Mar 26, 2012.
  1. Mar 26, 2012 at 1:10 PM
    helibear
    helibear [OP] Member
    Greg
    Indiana
    2012 Tacoma Access Cab 4X4 V6
    I'm finishing up installing a set of RideRite airbags on a '12 Tacoma. I don't like the look of the switch/gauge panel installed as an "add on" in the cab and plan to install it in the driver's side equipment box located at the rear of the bed.
    The control switch will fit one of the vacant 7/8" X 1.5" switch cut-outs on the driver's side dash, but I can find no acceptable place for the round 2 1/16" gauge. If, however, I could find a pressure gauge that would also fit one of these switch cut-outs my problem would be solved.
    I've had no luck searching the web ... anyone know of a source?
  2. Mar 26, 2012 at 5:35 PM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I doubt you'd find a gauge but you might find a digital read out that small, check summit?
