7" fabtech lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toy 2, May 18, 2015.
  1. May 18, 2015 at 1:41 PM
    toy 2
    toy 2 [OP] Well-Known Member
    Dave
    Reno, NV
    Ok so I have been doing a lot of reading trying to figure out how to get an extra 1" of lift out of my DB fabtech lift. I have the rear handled so all im trying to get figured out is how is the cheapest esaiest way to get an extra 1" in height in the front. 06 DCSB with fabtech 6" DB lift and 35" toyo MT tires. Can I just put longer coils on the stock shocks?
  2. May 18, 2015 at 1:51 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    sure... an extra inch needed on your "truck" gotcha ;)
  3. May 18, 2015 at 1:54 PM
    pudge151
    Sean
    Connecticut
    but seriously im not sure how DB lifts work but im guessing you could add 5100's and set @ .85" but don't quote me
  4. May 18, 2015 at 2:03 PM
    pudge151
    Sean
    Connecticut
    but he really needs that extra inch...hence the 6" lift to begin with
  5. May 18, 2015 at 2:55 PM
    toy 2
    Dave
    Reno, NV
    I was under the understanding that the 6" lift with the dropped diff would be ok pushing the lift a little. I know the 3" lifts pushes the limits of the cv angles at 3" because the diff stays in factory location. with the fabtech 6" lift my cv angles are very close to stock angles. Am I wrong here?
  6. May 18, 2015 at 2:58 PM
    toy 2
    Dave
    Reno, NV
    What are you refering to when you say setting them to .85"? Is that just preload on the spring. .85" down from the top of the shock?
  7. May 18, 2015 at 3:05 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    What are you trying to accomplish this for exactly? Perhaps your needs would just be better served by trimming some fenders and sheetmetal?
  8. May 18, 2015 at 3:24 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    Give Armen @ Fabtech a call directly. He is the tech God there. If it can be done at all, he'd be the one to tell you how.
  9. May 18, 2015 at 3:34 PM
    pudge151
    Sean
    Connecticut
    not sure how far it preloads it down, but it lifts the front .85"
  10. May 18, 2015 at 3:42 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    A 6" DB lift simply moves the mounting point for the LCA's down 6" so a 6" DB lift when installed with no preload on the CO's provides OE angles on everything...that is the whole point of the DB you don't even need aftermarket UCA's they also still sit at OE position because the aftermarket spindles with the DB kit are 6" taller too ( and way beefier than the OE spindles BTW ). If he add's a little preload to his 6" lift to gain an inch in the front it is exactly the same as adding an inch of pre load to a stock truck.
    For those wondering why he would want to raise it up an inch it is most likely to level the truck, most of DB kits lift the truck with the OE low front end rake maintained and most people want to sit level so the options are to lower the rear or lift the front a bit.
    OP - to answer your question - no a taller coil will not do anything, a stronger coil may hold the front end up higher though...but will ride stiffer. If you do not have adjustable coil overs then your only option would be to buy some or buy some 5100's as someone else managed so that you can adjust the 5100 to the next setting.
  11. May 18, 2015 at 3:43 PM
    toy 2
    Dave
    Reno, NV
    I have read that somewhere. So the lift puts the control arms at there "Movement" limit? So would I have to get aftermarket control arms? Lower and upper?
  12. May 18, 2015 at 4:14 PM
    toy 2
    Dave
    Reno, NV
    That's what I was asking. Thank you for the answer.
  13. May 19, 2015 at 5:43 AM
    toy 2
    Dave
    Reno, NV
    Just ordered my adjustable 5100's from Wheeler's off road. Thanks for all the help.
