7 pin Connector broken, what to do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImWarren, Mar 10, 2013.
  1. Mar 10, 2013 at 4:30 PM
    ImWarren
    ImWarren [OP] Well-Known Member
    Warren
    South Carolina
    2013 Double Cab manual
    Hey guys, I broke my 7 pin connector today climbing a hill. It was not a very tall hill, but it was kinda steep. There were rocks at the bottom and when I got up it, my rear end hit the rock and it destroyed the connector. The only part left is the dangling wire. I am very upset about this because the truck is not even 2 weeks old. What should I do? Will it get replaced under warranty? Should I take it to the dealership? Or should I order another off line? Any help is greatly appreciated!
  2. Mar 10, 2013 at 4:41 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Dealership wont warranty damage that you caused.
    Just go to an auto parts store and buy a new one. The package will explain which wires go where.
    White - Ground
    Blue - Electric Brakes
    Yellow - Left Signal
    Red - Right Signal
    Black - Power
    Red - 12v
    Brown - Running lights
  3. Mar 10, 2013 at 4:44 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    This^^^
    Don't even think about replacing it with one from a stealership unless you like to throw away money. I picked one up from NAPA for a few bucks and mounted it through the bumper. Or you can try to find one in a local junkyard.
    Edit- Here's a couple threads about mounting it differently-
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/195547-custom-7-pin-relocate.html#post4269027
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/114216-diy-relocate-trailer-harness.html
  4. Mar 10, 2013 at 4:53 PM
    ImWarren
    Warren
    South Carolina
    Should I get an aftermarket one or an OEM? I need the mounting bracket as well because mine is bent.
  5. Mar 10, 2013 at 4:55 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I dont think Toyota makes the trailer connector. They just buy from the manufacturer and mark it up Toyota style
  6. Mar 10, 2013 at 4:55 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    You can check the Buy/Sell threads to see if anyone's ditching their OEM bracket. Lots of folks peddle the bumper after switching to armor.
  7. Mar 10, 2013 at 4:56 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I cut one off a jeep and bolted it to my bumper. Used the jeep mounting bracket as well. Just get something cheap from NAPA and splice it in. Bobbb's links have good ideas.
  8. Mar 10, 2013 at 4:57 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Dude I know the feeling, I done the same thing on my 2012 not too long ago. I was kind of lucky though. I just broke the weld holding it to the frame and everything else was still in tact.
    Do what the other guy said, go to Autozone or any regular parts house and pick you up a new 7 pin plug and wire it up. I can also tell ya that your existing wiring runs up to right behind the bumper in the center and has a white plug, un plug it right there and make it easy on your self to connect the new plug.
    Since my plug was still in tact I didn't need to do the new wiring and stuff I just needed a way to mount it so it wasn't hanging under the truck. I used this write up here to help me out.
    http://www.toyotanation.com/forum/6...ailer-harness-relocation-diy.html#post1652523
    In this thread they talk about the different ways to mount the plug. I didn't like loosing the plate light so I opted to drill the 2 inch hole. I was TRYING to take my stock plug apart like that thread talked about but it was stubborn and I found it MUCH easier just to unplug the whole thing from behind the bumper like I told ya about before. Drill ya hole, and mount your new plug between the plate light and plate. This way it is up and out of the way and ya aint gotta worry with breaking it again, and it still looks really clean too! Good luck with your fix!
  9. Mar 10, 2013 at 5:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Two options:
    Remove one of the two license plate lights, dremel out the hole to fit the 7-pin connector. This gives the most ground clearance.
    Buy the OE bracket online at a cheaper price than the dealer, somewhere like Toyotapartsales.com . It's possible to mount the bracket at 90 deg orientation (so the outlet points down). This gives it extra clearance.
  10. Mar 10, 2013 at 5:48 PM
    ImWarren
    Warren
    South Carolina
    Thanks for all the advice. I just went to take another look at it and it turns out that the bracket is bent up under the truck.
  11. Mar 10, 2013 at 6:04 PM
    ImWarren
    Warren
    South Carolina
    Here are some pictures
  12. Mar 10, 2013 at 6:09 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    i did this^ easy and cheap
  13. Mar 10, 2013 at 6:16 PM
    MudFlap
    Tim
    2012 TRD Off Road
    Yeah it looks like ya mangled it up pretty good. I would get a new plug from walmart or autozone and drill the holes needed to mount it to the bumper just to the left of the license plate. This IMO is the cleanest way to keep your plug and to keep it from getting mangled again.
    If you decide to go this route don't be afraid to shoot me a pm with questions, I'm always willing to help.
  14. Mar 10, 2013 at 6:27 PM
    ImWarren
    Warren
    South Carolina
    Thanks man, I really appreciate it. The people on this site are so helpful. I think the plug is still good but the casing is broken. Any idea where I can get a new plug cover and wire casing?
  15. Mar 10, 2013 at 7:05 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I gotta say, your differential and inner rims are so clean, you can eat off of them.
    Let us know what you spend on a new plug. :)
