7 pin help
Discussion in 'Towing' started by empty hull, Apr 14, 2013.
  1. Apr 14, 2013 at 2:06 PM
    empty hull
    empty hull [OP] Active Member
    Tim
    Baton Rouge, La
    Prerunner V6 SR5 TRD Off Road
    I just bought a boat and will pick it up next Saturday. The trailer is having surge brakes installed and the salesman stated it will use a 5pin flat connector. When I got back from Florida, I looked into my glove box and noticed that I only have the 7-pin to 4-pin adapter #PT791-89040. Do they make a 5-pin model that will fit. Truck is a 2009 Tacoma TRD Offroad 2wwd. Thanks, Tim
  2. Apr 14, 2013 at 2:12 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Can the boat dealer not sell you a 7 to 5 pin adapter? You can find one at a bunch of stores, even Home Depot.
  3. Apr 14, 2013 at 2:19 PM
    empty hull
    Tim
    Baton Rouge, La
    Didn't realize that it was a 7 to 4 pin adapter until I got back to Louisiana. I have read that some connectors do not work/fit the Toyota. I do see one #51-30703 and #85212 from Auto Zone but not sure these will fit. Just trying to eliminate a problem before I go back and pick this boat up in Florida and head back home. :) Tim
  4. Apr 14, 2013 at 2:24 PM
    ajohnson
    Andy
    Charlotte, NC
    I was thinking you could ask them to have one when you pick the boat up. I have not heard about adapters not working on a Tacoma. I have bought 2 from different stores and not had a problem. But if you go to a place like Auto Zone or whatever, ask if you can make sure it fits before you drive home with it.
  5. Apr 14, 2013 at 2:30 PM
    empty hull
    Tim
    Baton Rouge, La
    That is a good idea. I wonder if the can just wire straight to a 7 pin and be done with it? Tim
  6. Apr 14, 2013 at 2:33 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    You could put a 7 pin connector on the boat. Just have a couple empty pins but it would work.
  7. Apr 14, 2013 at 2:34 PM
    ajohnson
    Andy
    Charlotte, NC
    Either way. I personally would go with 2000GT's suggestion, wire a 7 pin to the boat. That way you can have the 7 pin on your truck if you ever need it.
  8. Apr 14, 2013 at 2:38 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    wal mart has 7 pin to 4flat and 5flat. it has both 4 and 5 flat. i have one.
  9. Apr 14, 2013 at 6:31 PM
    empty hull
    Tim
    Baton Rouge, La
    Thanks guys for all the info. I do not think I should have a problem next weekend. :) Tim
