7 pin plug loose, when plugged in.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by texbaz, Dec 16, 2022.
  1. Dec 16, 2022 at 8:33 PM
    texbaz
    texbaz [OP] Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Picked up a New Travel trailer, when connecting the trailer I noticed the 7 pin plug is pretty loose in the truck receptacle. There is hardly no retention from the blade style pins or the center round pin,the plug is actually being retained by the plastic nub on the plug locking into the receptacle door. Just wondering if this is normal? Can the retention be improved?
    Inside the truck receptacle is very clean,same with the plug. In the end pulling the trailer gave no indication of a problem.
  2. Dec 16, 2022 at 8:52 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    This is how it works.
    Make sure that the door tab locks over the end of the plug and you'll be fine.
    texbaz[QUOTED][OP] likes this.
  3. Dec 16, 2022 at 9:05 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Mine will sometimes wiggle loose even with the tab inside the flap. I took a roll of electrical tape and put a couple wraps around the edge of the plug. Fits tighter, no more jiggles.
    texbaz[OP] likes this.
  4. Dec 16, 2022 at 9:09 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    If it didn't give you a problem, dont go looking for one. " if it ain't broke..."
    ToyoTaco25 and CT Yankee like this.
  5. Dec 16, 2022 at 10:06 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Does everything function otherwise? You can push outward the pins in the truck’s connector. Just be careful not to bend too far or you’ll flatten the blades into the housing. Also put some dielectric grease on the pins.
  6. Dec 16, 2022 at 10:26 PM
    texbaz
    "Buffalo Creek" TX
    Your response cracks me up. You obviously don't know just how loose it is. But thanks keep em coming.
    vicali likes this.
  7. Dec 16, 2022 at 10:28 PM
    texbaz
    "Buffalo Creek" TX
    I get it, but it's such an integral part of towing. It doesn't give a real positive feel. Anyway thanks
  8. Dec 16, 2022 at 10:30 PM
    texbaz
    "Buffalo Creek" TX
    Thanks yeah I'll give that a try bout the only thing.
  9. Dec 17, 2022 at 2:47 AM
    Evostaco
    Nebraska
    I feel a yo mama joke, but I'll refrain
    ToyoTaco25 likes this.
  10. Dec 17, 2022 at 7:46 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    It’s possible that the trailer plug is worn.
    try a new 7 to 4 pin adapter with the test lights in it and see how it feels. If that’s tight and all the light work, think about replacing your plug on the trailer.
  11. Dec 17, 2022 at 8:22 AM
    GeronimoCO
    GeronimoCO Active Member
    2016 TRD Off-Road Double Cab
    Mine fits a bit loosely as well... It worried me at first but the plastic tab seems to keep it in place and the lights all work consistently. I like the idea of a few layers of electrical tape around the plug, or may try a zip tie if it becomes an issue but long story short I think it's normal - just how it fits.
  12. Dec 17, 2022 at 8:29 AM
    texbaz
    "Buffalo Creek" TX
    Thanks, it's all new stuff, New Casita travel trailer the plug is what comes with the trailer
    The receptacle is came on the truck and was never used until now 2018 Tacoma TRD Off-Road.
    Even inspected inside the receptacle clean, Gota be slight dimensional changes with plug manufacturers. Maybe a layer of electrical tape, or a reusable toe rap will be ok Thanks
  13. Dec 17, 2022 at 8:30 AM
    texbaz
    "Buffalo Creek" TX
    Thanks, I'll try them both sounds like a plan.
  14. Dec 17, 2022 at 9:02 AM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    it’s all fun and games until you realize you don’t have trailer brakes anymore..
