7-pin towing socket (no power)
Discussion in 'Towing' started by 06Tacoman, Jun 27, 2010.
  1. Jun 27, 2010 at 5:42 PM
    06Tacoman
    06Tacoman [OP] Member
    Brian
    South Jersey
    06 SR5 Double Cab Short Bed
    I've read alot about what can be wrong...ground etc.
    Would like to start with the fuses, but there are several that read towing.
    Are they all related to the 7-pin socket?
    Which ones are for the 7-pin socket?
    Sounds like it may be the ground.
    Wouldn't at least some of the lights work?
    I appreciate all suggestions...really need some fuse insight.
    Thanks Guys
    :confused:
  2. Jul 10, 2010 at 12:05 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Assuming you have the factory towing package, the 12v pin is only live when the truck is running, and it will be one of the under hood fuses. If it is aftermarket, it is likely not wired.
