7 qts added and still no dipstick reading
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Feb 24, 2019.
  1. Feb 24, 2019 at 5:56 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You could also take a small drill bit and drill through the low/high divots, another way to help hold oil for a better reading.
    Opihi59 and HelloMyNameIs like this.
  2. Feb 24, 2019 at 5:56 PM
    Northwoodshyun
    Northwoodshyun Well-Known Member
    St. Paul MN
    One thing you can do is place the dipstick over and imprint it on a tissue paper to see where the fluid stops. Do you have a color deficiency (i.e., failing color blind test) issue?
  3. Feb 24, 2019 at 5:56 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    That upper divot has oil in it, clean it out well and try again.
    CusterFan likes this.
  4. Feb 24, 2019 at 5:57 PM
    SaulGoodman
    SaulGoodman Well-Known Member
    24 SR5 4x4
    New synthetic oils are so colorless you almost have to turn the dipstick until light reflects off to see what is “wet” with oil... you can also use this method on your gal.
  5. Feb 24, 2019 at 5:57 PM
    OnHartung'sRoad
    Thats a good idea- my dad used to use paper from a brown paper bag.
  6. Feb 24, 2019 at 5:58 PM
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Hold the dipstick just slightly down at the end. Now and lay it on a clean white paper towel, You will see a wet line corresponding to the oil level.
  7. Feb 24, 2019 at 5:58 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Or you could use newspaper. Check oil AND check the new low price on chicken breasts at your local market!
  8. Feb 24, 2019 at 6:02 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    To know for sure do not start engine for at least 10 minutes. Remove stick and wipe clean. Reinsert stick and allow to sit for about 1-2 minutes. Remove stick and with a clean napkin start to slowly slide it down the stick toward the end. As soon as it hits oil you’ll see the napkin get darker/wet. Beige napkins tend to show darkening better than white.
    specter208 likes this.
  9. Feb 24, 2019 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    This.
    Cocolocobean and whatstcp like this.
  10. Feb 24, 2019 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You said breasts...
    Cocolocobean and StayinStock like this.
  11. Feb 24, 2019 at 6:13 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    You overfilled a bit.
  12. Feb 24, 2019 at 6:13 PM
    stun gun
    Aaronski
    Tacomas.
    Tube tops!
  13. Feb 24, 2019 at 7:50 PM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Good way to check new clear oil.....dip the stick, pull wipe it off, dip again then pull it out and carefully lay the dipstick flat on a paper towel the oil level print will show plainly on the paper towel.
    r1200gs4ok likes this.
  14. Feb 24, 2019 at 8:49 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    How did you know I was high?
    Cocolocobean, Skydvrr and tcjacado like this.
  15. Feb 24, 2019 at 8:50 PM
    #35
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Cuz you dumped 7qts of oil in your truck and couldn't read the dipstick...
  16. Feb 24, 2019 at 8:55 PM
    #36
    tcjacado
    tcjacado Well-Known Member
    But I am illiterate :(
    boynoyce and Amanelot[QUOTED] like this.
  17. Feb 24, 2019 at 8:58 PM
    #37
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Everyone knows your high man....they are all staring at Y O U
    jtmiller2011 and boynoyce like this.
  18. Feb 24, 2019 at 8:59 PM
    #38
    Herniator
    Edmonton
    Oh Shit!
  19. Feb 24, 2019 at 9:01 PM
    #39
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    This! It is way easier to see after leaving it out and letting oil in the tube run back down.
  20. Feb 25, 2019 at 4:50 AM
    #40
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    :laugh::rofl::laughing:
