7 qts added and still no dipstick reading
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Feb 24, 2019.
  1. Feb 25, 2019 at 4:51 AM
    #41
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  2. Feb 25, 2019 at 7:06 AM
    #42
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I have a discount coupon for the Eye center. It's overfilled.
    Sorry, couldn't resist.
    G.
  3. Feb 25, 2019 at 7:16 AM
    #43
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Thats what she said.
    JNG and stun gun[QUOTED] like this.
  4. Feb 25, 2019 at 7:17 AM
    #44
    Tacowin1013
    Yep, oil on there--its hard to read i usually fill at 6 qts, let the engine run for a few minutes, have a few beers and go back and check it
  5. Feb 25, 2019 at 7:20 AM
    #45
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Better drain some. Too much oil may get wipped up and froth from the crank shaft and you'll get air bubbles.
    Best bet is to get a brand new oil pan (or clean one out) and drain all the oil and refill.
  6. Feb 25, 2019 at 7:25 AM
    #46
    Tacowin1013
    a whole new oil pan? couldn't he get away with just a flush and refill? or are you suggestng there's still air bubbles stuck in the pan?
    stun gun likes this.
  7. Feb 25, 2019 at 7:27 AM
    #47
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Yes. Bubbles from the froth infect the oil pan blast baffles. It’s just good practice.
  8. Feb 25, 2019 at 7:30 AM
    #48
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not the engine oil pan, the oil container you drain into (name is escaping me).
    Just drain it and pour it back in until properly filled then pour the rest into the oil bottle for later use.
  9. Feb 25, 2019 at 7:32 AM
    #49
    Tacowin1013
    Ahhhh ok, i was thinking it was a bit overkill haha. I would've just suggested a fresh start, fresh oil and move on. 6 qts of mobil1 isn't terribly expensive---cheaper than a new engine.
  10. Mar 1, 2019 at 9:49 AM
    #50
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    7 quarts of Royal Purple is not cheap. You can't buy 6.2qts.
    Anyway, what I ended up doing was loosening the drain plug and letting some drain, then checking. Did this until I had drained a little over a qt. Still could not really read the dip stick, but it seemed to be right in the middle of the two divots. The old lady has been driving the taco ever since the oil change, I'll take a look here in a bit and see how it looks.
  11. Mar 1, 2019 at 9:55 AM
    #51
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Years ago I pulled the dipstick on my F-150 and it was bone dry. Upon looking farther I hole had rusted through the tubing right at a bend and dipstick hanging out in mid air. Took a piece of beer can wrapped it around tubing and clamped on -fixed!!
  12. Mar 1, 2019 at 10:00 AM
    #52
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Don't know if this could be relevant, but years ago when dipping an underground fuel storage tank, my father would rub a tiny amount of chalk on the stick before dipping it so the level would be easily readable...
  13. Mar 1, 2019 at 11:15 AM
    #53
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You cannot read the oil level by just pulling it out. You MUST pull it and clean it and wait 10 min or so....longer the better.
    Now insert it and remove to read.
    If you want to double-check it, same routine.....pull/clean/wait/stick it/pull it/clean/wait, etc etc.
    The damn tube must touch the side of the dip syick down there and it "wicks" up oil onto the stick.
    Good luck. Hard to read but in sunlight is best.
