7 quarts of oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by habibipls, May 11, 2025.
  1. May 11, 2025 at 11:13 PM
    habibipls
    habibipls [OP] Member
    ‘23 TRD Sport 4x4 3.5L
    Did an oil change but mistakenly filled in 7 quarts of oil in my ‘23 TRD Sport 3.5L… usually diligent with 6.1-6.2 but was lost in the sauce and put the whole thing in.
    How big of a deal is this? Are there any potential lasting damages that this can do?
  2. May 11, 2025 at 11:16 PM
    MGMDesertTaco
    Potential damage can occur. Undo the drain bolt and put it back after a couple seconds. If you have a clean drain pan you could drain a little extra and add back whatever is needed for 6.2 qts.
    HondaGM, DavesSR5, TS4x4 and 5 others like this.
  3. May 11, 2025 at 11:21 PM
    habibipls
    Yeah I think I should, if anything, just for peace of mind… honestly wondering what the worst is that could happen. Don’t want to find out though. Duality of man or whatever…
    HondaGM likes this.
  4. May 12, 2025 at 1:17 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Maybe some of our more enlightened members can point - I thought I saw on here (? can't seem to find) some video of possibly russian guys or whatever overfilling an engine with a cutout window installed. They kept adding by specific amounts and it took muuucho more than the design level to kill the engine. Like almost filled to overflowing. The oil flow in the window was entertaining. Anybody remember that?
    Anyway my point is, yes an overfill may do something, but in all likelyhood your amount probably won't.
  5. May 12, 2025 at 1:20 AM
    Archimedes
    23 DCSB TRD OR MGM
    Similar thought just occured to me after re-reading yours. Instead of the "oh shit" lol of the oil drain, since its a '23 6 cyl maybe try just removing the drain plug of the oil filter and get a little at a time. Should be less that half a qt at a time and you can fine tune the removed amount.
  6. May 12, 2025 at 2:30 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Just FYI….6 works. I usually buy a 5qt jug plus one quart when I do a change. Been doing that for years and every change I just pour in the 6 and be done with it, that always puts it right at 3/4 up to the top of good to go section on the dip stick
    HondaGM, vme, DavesSR5 and 5 others like this.
  7. May 12, 2025 at 4:12 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
  8. May 12, 2025 at 5:06 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You're borderline. Overfilling by 1/4-1/2 qt generally doesn't hurt anything, but you're closer to 3/4 of a qt. I'd probably drain out a little. It isn't rocket science, and you don't have to worry about being exact.
    Next time I'd put in 6 quarts and call it good. For one thing you NEVER get every bit of the old oil out. If you put in 6 quarts along with the tiny bit left over will probably be perfect. At most you'll be a tiny bit below the top mark on the dipstick. Anywhere between the lines on your dipstick is fine. I never add partial quarts if I'm a little low. I wait until I'm a full quart low then add a full quart. Or if it's close to time to change oil just wait a few days then change it
    HondaGM and Barsoom like this.
  9. May 12, 2025 at 5:19 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Drain to the full line. Do it.
    whoareyou133, HondaGM and Inyo_man like this.
  10. May 12, 2025 at 5:45 AM
    stielinc
    stielinc Well-Known Member
    I've always understood that overfilling can lead to oil pressure issues, dunno if this is true or not..
    whoareyou133 likes this.
  11. May 12, 2025 at 5:59 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Not that big a deal but I would still correct it. Get a clean receptacle and drain it all out. Then add 6 qts of it back.
    But then again, what the hell do I know?
    HondaGM and TacoTime55 like this.
  12. May 12, 2025 at 7:13 AM
    hammerdog
    hammerdog Well-Known Member
    For peace of mind, you can buy a $7.99 oil extractor hand pump at Harbor Freight and extract the amount of oil you overfilled. Much easier and less messy than taking out your oil drain bolt.
    HondaGM and Chew like this.
  13. May 12, 2025 at 7:13 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Drain the excess, next time just add 6 quarts. Dipstick will show 3/4 full.
    HondaGM likes this.
  14. May 12, 2025 at 7:25 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Part it out...
  15. May 12, 2025 at 7:36 AM
    pstod14
    pstod14 New Member
    Paul
    2023 Black Tacoma TRD Off Road
    Interior Mods only
    I'd drain a little out for sure.
    HondaGM likes this.
  16. May 12, 2025 at 7:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If oil is overfilled to the level of the crankshaft, the crankshaft can stir up the oil and cause it to foam. Air bubbles don't lubricate. I don't know if 7 quarts is enough to do it.
    There are oil extractor hand pumps which allow you to suck out the oil from the dipstick tube. That's the least invasive way without disturbing the drain plug gasket or oil filter O-rings. Example only (I have no experience with this particular product): https://www.amazon.com/EWK-Extractor-Changer-Fluid-Evacuator/dp/B079FJ21DV Some people use this routinely for oil changes in apartment buildings. Looks like one of the reviewer pics is from a Tacoma:
    [​IMG] [​IMG]
  17. May 12, 2025 at 9:50 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I keep clean empty 1 quart oil containers. During an oil change when I'm ready to fill, I pour out .9 quart into the small jug, leaving the 6.1 that I want in engine in the new large jug. The partial quart in the small jug I label with specs and date using masking tape. You can then dump the rest of the big jug in the engine without worry of over filling.
    HondaGM likes this.
  18. May 12, 2025 at 9:54 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    How full is it on the dipstick? When I change my oil, it takes about 6.7qts to achieve the full mark on the dip stick. I wouldn't bat an eye at 7qts at all. I've drained over 10qts from a 3.5 (highlander) that was running just fine.
    HondaGM likes this.
  19. May 12, 2025 at 9:59 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    https://www.youtube.com/watch?v=VaTbfvzNbxQ
    HondaGM and tarbal255 like this.
  20. May 12, 2025 at 10:22 AM
    Archimedes
    23 DCSB TRD OR MGM
    :rofl: That was it! Some good lines in there.... almost like I heard them on here in "serious talk" >
    > The oil is running out in a heavy stream near the end after the pan lets loose. Guy says "I'm gonna need a rag"
    > Then " It's good for rustproofing"
    HondaGM likes this.
