7" rim with 12.5" tire
Discussion in 'Off-Roading & Trails' started by bmolda1, Jul 3, 2013.
  1. Jul 3, 2013 at 12:26 PM
    bmolda1
    bmolda1 [OP] Member
    Brian
    NOLA
    '13 Super White TSS
    General tire question not a taco question...
    I know it CAN be done, but does anyone have any practical experience running 12.5" wide tires on a 7"rim? What did you like/not like about it?
    I'm putting 33s on my Grand Wagoneer and I like the stock rims but want as wide a tire as possible. From what I have read, people begin to disagree when you get to 12.5" width on a 7" rim.
  2. Jul 3, 2013 at 12:35 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    you may be able to pull it off on the street, but once you need to air down you're going to lose that bead right quick.
  3. Jul 3, 2013 at 12:57 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Actually the narrower wheel will hold a bead better than a wider rim. A wide tire on a narrow rim will "crown" the tire and you'll get uneven wear down the center of the tire.
    Edit: 8" wheel would be best.
  4. Jul 4, 2013 at 2:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No.
    A 7" wheel will pull the tire in to much. You'd have to run at like 20psi for even wear.
    8" is the smallest you can run on a 12.5.
  5. Jul 4, 2013 at 2:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You did the chalk test?
    Cause I have to run 32 for even wear..and I weigh a hell of a lot more then you do..and 8" rim
  6. Jul 4, 2013 at 3:02 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I would run atleast a 8 or 9" wheel
  7. Jul 4, 2013 at 3:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gtfo haha
  8. Jul 4, 2013 at 3:05 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The old rule of thumb was tire was no more than 2" wider than rim...but I guess that has changed.
  9. Jul 8, 2013 at 1:12 PM
    BradyT88
    BradyT88 Well-Known Member
    n0rth runs a 12.50 on a 7" wheel without issue that I am aware of. Granted I don't think he is overly concerned with the center wear and he now has some smaller tires that he DD's.
  10. Jul 8, 2013 at 1:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    His arent 12.5s. He has never run 12.5s I thought..all tall and skinny??
  11. Jul 8, 2013 at 1:43 PM
    BradyT88
    They are 36x12.50's they just have a narrow tread like KM2's. Mine are 10" wide tire but the tread is only 7" wide.
  12. Jul 8, 2013 at 1:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh..thought they were 36x10 or 11s
  13. Jul 8, 2013 at 1:48 PM
    BradyT88
    Nope. I have yet to find a tire larger than a 35 that is skinnier than a 12.50. They just don't exist. haha. Except for the 255/100R16, which is extremely rare. (it's a 36x10)
  14. Jul 8, 2013 at 1:52 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Whole slew of Swampers out there.
    http://www.intercotire.com/tires.php?id=10
  15. Jul 8, 2013 at 1:56 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    ^which is what he runs
  16. Jul 8, 2013 at 1:56 PM
    BradyT88
    No there isn't... That is where I first looked... They make a few 35x10's and such, but everything 36+ is 12.50+...
  17. Jul 8, 2013 at 1:57 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    from his sig
    36x9.8R16 TSL Radials
  18. Jul 8, 2013 at 1:59 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    x2.. def don't like like 12.5s
  19. Jul 8, 2013 at 1:59 PM
    Boone
    Boone, NC
    Airbags deployed
    I'm looking at actual cross sections and heights of tires, not the quoted numbers. There are 9 of them that match that criteria in TSL's alone.
  20. Jul 8, 2013 at 2:04 PM
    BradyT88
    n0rth's are listed as 36x12.50R16's. They are listed as having a 9" wide tread pattern and are 12.6" wide at the widest point on a 10" wheel. So they are likely a bit skinnier than that on his 7" wheels, but they still make my 10" wide tires look skinny.
    Just like my tires are 255/85R16's which are a 33x10, they have a 7" wide tread pattern and measure about 10" wide at the widest on my 8" wheel.
